Selecting Device with both Temperature and Humidity sensors
I am trying to make a blueprint where I can select devices with both a temperature sensor AND a humidity sensor.
Here is the start of the blueprint (only selector-part):
blueprint:
  name: Test select T&H devices
  description: >-
    Try to select devices which has both humidity AND temperature sensors.
  domain: script
  input:
    test_device:
      name: Test Device selecting T&H devices
      description: select T&H device
      selector:
        device:
          entity:
            - domain: sensor
              device_class:
                - humidity
                - temperature
This is just the selector-part of the blueprint. This is giving all devices that has sensors with device_class humidity OR device class temperature.
I also tried:
      selector:
        device:
          entity:
            - domain: sensor
              device_class: humidity
            - domain: sensor
              device_class: temperature
this also gives the OR option
I need the option to select devices with has both a temperature and a humidity sensor, the AND-option
Can this be done?
Don’t think so:
entity list (optional)
When entity options are provided, the list of devices is filtered by devices that at least provide one entity that matches the given conditions. Can be either a object or a list of object.
I read that, but I was hoping for some undocumented feature known by someone …
