Selection boxes unreadable after recent update
Hello, I have used a custom theme for a few years but a recent update must have changed something about the dropdown/selection boxes and I can’t for the life of me figure out how to fix it.
will:
  # Global
  background-image: "center / cover no-repeat fixed url('/local/images/glens.png')"
  lovelace-background: var(--background-image)
  primary-color: "#228b22"  # from Apple systemOrange dark mode
  light-primary-color: "#B6B6C1"  # (icons on left menu) (light: systemGray5 from iOS dark mode, dark: XXX)
  primary-background-color: "#2c2c2e"  # systemGray5 dark mode
  secondary-background-color: rgba(25, 25, 25, 0.9)
  divider-color: rgba(152, 152, 157, 0.3)  # from Apple systemGray dark mode
  accent-color: rgba(255, 159, 9, 1)
  # Text
  primary-text-color: "#FFF"
  secondary-text-color: "#d3d3d3"
  text-primary-color: "#FFF"
  disabled-text-color: "#555"  # XXX: https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/2
  text-dark-color: "#FFF"
  # Sidebar Menu
  sidebar-background-color: var(--primary-background-color)
  sidebar-icon-color: var(--light-primary-color)
  sidebar-text-color: "#F1F1F1"
  sidebar-selected-background-color: var(--primary-background-color)
  sidebar-selected-icon-color: "#FFF"  # (light: systemGray5 from iOS light mode, dark: XXX)
  sidebar-selected-text-color: var(--sidebar-selected-icon-color)
  # States and Badges
  state-icon-color: "#FFF"
  state-icon-active-color: rgba(255, 214, 10, 1)  # or make light icons yellow when active: rgba(255, 214, 10, 1)
  state-icon-unavailable-color: var(--disabled-text-color)
  paper-item-icon-active-color: rgba(255, 214, 10, 1)  # see https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/30
  # Sliders
  paper-slider-knob-color: "#FFFFFF"
  paper-slider-knob-start-color: var(--paper-slider-knob-color)
  paper-slider-pin-color: var(--paper-slider-knob-color)
  paper-slider-active-color: "#0984ff"  # from Apple systemBlue dark mode
  paper-slider-secondary-color: var(--paper-slider-knob-color)
  paper-slider-container-color: rgba(255, 255, 255, 0.5)
  paper-slider-font-color: "#000"
  ha-slider-background: none !important
  # Labels
  label-badge-background-color: "#23232E"
  label-badge-text-color: "#F1F1F1"
  label-badge-red: rgba(255, 159, 9, 0.7)  # from Apple systemOrange dark mode
  # Cards
  card-background-color: var(--secondary-background-color)  # Unused entities table background
  paper-listbox-background-color: var(--primary-background-color)
  ha-card-border-radius: 20px
  ha-card-background: rgba(10, 10, 10, 0.4)
  paper-card-background-color: var(--ha-card-background)
  ha-card-border-width: 0  # https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/82#event-7732695357
  # Toggles
  paper-toggle-button-checked-button-color: "#484848"
  paper-toggle-button-checked-bar-color: "#484848"
  paper-toggle-button-unchecked-button-color: var(--paper-toggle-button-checked-button-color)
  paper-toggle-button-unchecked-bar-color: var(--disabled-text-color)
  # Table row
  table-row-background-color: var(--primary-background-color)
  table-row-alternative-background-color: var(--secondary-background-color)
  # Switches
  switch-checked-color: "#30d257"  # XXX: remove when https://github.com/home-assistant/home-assistant-polymer/pull/4203 is in HA
  switch-checked-track-color: "#30d158"  # from Apple systemGreen dark mode
  switch-checked-button-color: "#FFF"
  # Other
  paper-dialog-background-color: rgba(55, 55, 55, 0.8)  # e.g., background of more-info
  paper-item-icon-color: white  # also should mini-media-player icon white (but doesn't work by itself)
  more-info-header-background: rgba(25, 25, 25, 0.5)
  lumo-body-text-color: var(--primary-text-color)  # see https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/42
  app-header-background-color: rgba(5, 80, 0, 0.4)
  markdown-code-background-color: "#464646"
  code-editor-background-color: "#161616"
  # Custom
  mcg-title-letter-spacing: .15em
  mini-media-player-base-color: white
  mini-media-player-icon-color: white
  # Added for https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/72
  # TODO: add description for lines below. Suggested in https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/72
  input-ink-color: var(--primary-text-color)
  input-fill-color: transparent
  input-disabled-fill-color: transparent
  input-label-ink-color: var(--primary-text-color)
  input-disabled-ink-color: var(--disabled-text-color)
  input-dropdown-icon-color: var(--primary-text-color)
  input-idle-line-color: var(--secondary-text-color)
  input-hover-line-color: var(--secondary-text-color)
  codemirror-property: var(--accent-color)
I did base this theme off one of the IOS themes that haven’t been updated in a while and they’re all doing the same thing with the white boxes.
I’d looked through a few old posts about similar issues but none of the additional options I’ve tried seem to change the colour of the boxes.
#  mdc-select-fill-color: var(--primary-background-color)
#  mdc-select-ink-color: var(--primary-text-color)
#  mdc-select-label-ink-color: var(--primary-text-color)
#  mdc-select-dropdown-icon-color: var(--primary-text-color)
#  paper-listbox-background-color: var(--secondary-background-color)
# Add to your theme yaml file
#  mdc-select-label-ink-color: var(--secondary-text-color)
# Fix for input fields / text boxes
#  mdc-text-field-fill-color: var(--primary-background-color)
#  mdc-text-field-ink-color: var(--primary-text-color)
#  mdc-text-field-label-ink-color: var(--secondary-text-color)
# Fix for dropdown background popup
  mdc-select-container-color: rgba( 75, 92, 105, 0.45)
  mdc-text-field-fill-color: rgba( 75, 92, 105, 0.45)
  mdc-text-field-ink-color: "#FFF"
  mdc-text-field-label-ink-color: "#FFF"
  mdc-select-fill-color:  rgba( 75, 92, 105, 0.45) #rgba( 10, 10, 10, 0.5)
  mdc-select-ink-color: "#FFF"
  mdc-select-label-ink-color: "#FFF"
  md-sys-color-surface: rgba( 75, 92, 105, 0.45)
I can change the text colour within the boxes with the text variables but the white boxes are ugly so I’d love to know what element I need to set the colout for to put them back to the nice grey they were last month.
I found this thread
Adding this to the bottom of my theme solved my issue.
  ha-color-form-background: rgba(25, 68, 2, 0)
  ha-color-form-background-hover: rgba(25, 68, 2, 0.6)
  ha-color-form-background-disabled: rgba(12, 17, 9, 0.38)
It’s cool you found a solution, but was it your theme? I seem to have the same recent issues from a recent update that I can’t seem to resolve. It appears on any dropdown & Im using the Mushroom select card.
everywhere I have a drop down, it’s gone all wonky. this is the standard light card.
It was my own theme but I modified one of the IOS themes.
Did you try adding the lines I added to mine to see if it fixed it?
Thanks, fixed for me!
hey, is it possible to add these lines to one of the standard Lovelace themes?
if so, do you know where to add it :see_no_evil:
Thank you for following up on this! I am a beginner using the ios-themes and got frustrated with not being able to see text boxes but this was an easy fix. I wish there was a way to apply it to the entire theme instead of one by one.
