Goal
Create a light switch that is decoupled from power delivery so the 9 Hue Bulbs in my Dining Room Chandelier can always be powered, while allowing use of the light switch on/off paddle.
Concept
I started with the following code fragment which uses the Home Assistant API to toggle the lights on or off when the toggle is flipped. Basically, if the API is connected, then have Home Assistant toggle the lights. However, if the API is NOT connected (because Home Assistant is offline currently) then use the relay to toggle power to the lights.
Code Snippet
script:
- id: hass_light_toggle
then:
if:
condition:
api.connected:
then:
# Have Home Assistant toggle the light.
- homeassistant.service:
service: light.toggle
entity_id: ${hass_light}
else:
# When HA is unavailable, toggle the relay.
- switch.toggle: relay
binary_sensor:
- platform: gpio
pin:
number: GPIO5
inverted: True
filters:
- delayed_on: 10ms
- delayed_off: 10ms
on_press:
- script.execute: hass_light_toggle
on_release:
Problem
This worked pretty well, but after a several rounds of: repeatedly toggle the switch, restart home assistant, toggle some more… I learned that sometimes the light switch toggle wouldn’t change the light state (it would stay on or off on the first toggle).
Solution
I settled on a reasonably simple solution of turning the relay back on, and turing the light on in Home Assistant if the relay was off when the switch was next toggled.
shelly01.yaml
# Shelly 1 Power Module
substitutions:
devicename: shelly1_01
upper_devicename: Shelly1 01
hass_light: light.dining_room
esphome:
platform: ESP8266
board: esp01_1m
board_flash_mode: dout
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_pass
# Enable Home Assistant API
api:
ota:
safe_mode: True
logger:
script:
then:
if:
condition:
api.connected:
then:
- if:
condition:
switch.is_off: relay
then:
# Turn the relay back on and turn on the light.
- switch.turn_on: relay
service: light.turn_on
else:
else:
binary_sensor:
- platform: gpio
pin:
number: GPIO5
inverted: True
filters:
- delayed_on: 10ms
- delayed_off: 10ms
on_press:
on_release:
switch:
# Relay is for internal use only. Do not expose to Home Assistant.
- platform: gpio
pin: GPIO4
restore_mode: ALWAYS_ON
More ESPHome code
If you want to see my other ESPHome code, this is my Github Repository.
