So I have AdGuard installed on proxmox alongside HA and I’m trying to add the AdGuard home assistant integration so I get all the things it provides.
So in the host I have the ip address of my AdGuard, and I know this is working because I have it up in my browser. Then port 3000 which is what I used. Username and password are in my iCloud Keychain but I’ve also tried manually copying these in incase. Then 2 tick boxes, one use an ssl certificate and verify ssl certificate which I believe should be off because I’m accessing it locally?
When they’re ticked it says failed to connect and when there unticked I get unknown error occurred, what am I doing wrong here?
Like I say I can access AdGuard in my browser so I’m not sure if there’s any kind of api things going on?
Thanks everyone!
Edit - weirdly I can’t login using chrome but works in safari
