I put together a small closed-loop system that automatically tunes how much my AlphaESS home battery charges overnight from the grid, based on what actually happens each night — the goal was simply to cut the monthly electricity bill without manually tweaking settings.
How it works:
- Each evening, an automation blends the next day’s solar forecast (Solcast) and the weather outlook into a tiered overnight charge target (40-90% range).
- Every morning it checks what actually happened: how low the battery got before sunrise, and how much was charged from the grid.
- Based on that outcome, it nudges the charge target up or down for future similar days (step_up/step_down, currently 5%/3%) — so it slowly converges toward “just enough” instead of always erring on the safe (expensive) side.
- A hard safety floor/ceiling (40-90% target, battery itself clamped 45-85%) makes sure it never risks running the battery flat before sunrise, no matter what the learning loop decides.
- A daily effect logger tracks whether each night was LOW (too conservative — battery barely used), HIGH (risked running low), or OK, so the whole thing is auditable in the HA logbook.
It’s 6 automations total, fully documented, MIT licensed:
GitHub - quanfuchen1981/ha-alphaess-battery-optimizer: Self learning Home Assistant automations for an AlphaESS home battery and solar system. · GitHub
Happy to answer questions if anyone wants to adapt it for their own inverter/battery setup.
