The idea
I've experimented a bit with self-referencing sensors. They might be useful for example for hysteresis. (I am aware of hysteresis sensors, but we can do more advanced things with this.) For example, we might have a sensor that produces on/off/keep values and then a binary sensor that takes those values:
private val binaryWindowOpenDef = BinarySensorDef.selfReferencing(
name = s"${friendlyName} window open",
stateFactory = self => windowOpenHysteresis.matches(
HysteresisStatus.Off -> Const(false),
HysteresisStatus.On -> Const(true),
HysteresisStatus.Keep -> self,
This generated a binary sensor like this (a bit manually polished output from Hagen; be aware of the difference between binary_sensor.my_room_window_open and sensor.my_room_window_open):
- "binary_sensor":
"name": "my room window open"
"state": '{{ \
false if (states("binary_sensor.my_room_window_open") == "off") \
else (true if (states("binary_sensor.my_room_window_open") == "on") \
else (unexpected_value)) \
) if (states("sensor.my_room_window_open") == "keep") \
\ else (\
true if (states("sensor.my_room_window_open") == "on") \
else (false if (states("sensor.my_room_window_open") == "off") \
The key part is that the definition of the sensor binary_sensor.my_room_window_open references itself if the source sensor's value is keep, so only on and off values change its state. I know one could do the same with an input_boolean and some automation that changes the values, but this is simpler and more declarative.
A recursive experiment
One might ask what happens when the source sensor has initially a keep value. We can do a simple experiment:
private val selfReferencingExp = BinarySensorDef.selfReferencing(
name = "self referencing experiment",
stateFactory = self => self
which roughly translates to:
- "binary_sensor":
"name": "self referencing experiment"
"state": '{{ \
false if (states("binary_sensor.self_referencing_experiment") == "off") else \
(true if (states("binary_sensor.self_referencing_experiment") == "on") else \
I appologize for the verbosity. It comes from the defensive way Hagen handles conversion from String to Boolean.
The binary_sensor.self_referencing_experiment is always off. This looks like the initial state of the template-based binary sensor is off, so it just keeps the value forever.
The questions
- Is self-referencing officially supported by Home Assistant? I haven't found any evidence of it either being supported or not being supported. (Or even encouraging/discouraging the self-referencing.)
- Can I rely on the initial value, as I do in the recursive experiment?
