I made an air sensor based on a ESP8266mod-12F with a MH-Z19b, a sth21, an aht10 and a bme280 for CO², humidity, temperature and athmospheric pressure.
- platform: mhz19
co2:
name: "Valeur CO² $long_devicename"
on_value_range:
- below: 400
then:
- switch.turn_off: red
- switch.turn_off: yellow
- switch.turn_off: green
- above: 399
below: 900
then:
- switch.turn_on: green
- above: 899
below: 2200
then:
- switch.turn_on: yellow
- above: 2199
then:
- switch.turn_on: red
temperature:
name: "Temperature MH-Z19 $long_devicename"
automatic_baseline_calibration: false
uart_id: uart_mhz19
update_interval: 30s
- platform: htu21d
temperature:
name: "Temperature SHT21 $long_devicename"
humidity:
name: "Humidite SHT21 $long_devicename"
address: 0x38
- platform: bmp085
temperature:
name: "Temperature BMP11 $long_devicename"
pressure:
name: "Pression BMP11 $long_devicename"
address: 0x77
switch:
# Bouton de redémarrage
- platform: restart
name: "Redémarrage $long_devicename"
# switch configuration to turn calibration on/off
name: "Calibration $long_devicename"
optimistic: true
on_turn_on:
mhz19.abc_enable: mhz19_calibration
on_turn_off:
mhz19.abc_disable: mhz19_calibration
# Gestion des LED
- platform: gpio
pin: GPIO14 #d5
icon: "mdi:led-on"
interlock: [yellow, red]
- platform: gpio
pin: GPIO12 #d6
icon: "mdi:led-on"
interlock: [green, red]
- platform: gpio
pin: GPIO13 #d7
icon: "mdi:led-on"
interlock: [yellow, green]
uart:
- rx_pin: GPIO05 #d1
tx_pin: GPIO04 #d2
baud_rate: 9600
i2c:
- sda: GPIO13 #d7
scl: GPIO15 #d8
scan: false
I know, this is not very nice but it was (roughly) working.
I had some trouble while booting, sometimes, it hangs, sometimes it starts in « no error mode » and nothing was working.
Removing some leds, mainly the red was helpful.
Then I installed a display on the I2C bus and added this part:
font:
- file: "arial.ttf"
- file: "arial.ttf"
display:
- platform: ssd1306_i2c
model: "SSD1306 128x64"
reset_pin: D0
address: 0x3C
lambda: |-
it.printf(0, 4, id(my_font2), "CO2");
it.printf(32, 0, id(my_font3), "%.1f ppm", id(mhz19_co2).state);
it.printf(0, 20, id(my_font2), "Temp");
it.printf(32, 16, id(my_font3), "%.1f °C", id(bme280_temp).state);
it.printf(0, 36, id(my_font2), "Hygr");
it.printf(32, 32, id(my_font3), "%.1f %%", id(aht10_hyg).state);
it.printf(0, 52, id(my_font2), "Press");
it.printf(32, 48, id(my_font3), "%.1f hPa", id(bme280_pr).state);
it has been working fine for two months.
But I still want my status leds.
I replaced my 3 leds with a single addressable led, a PL9823 (compatible WS2812).
If I am able to lit it in red (or any color I want from the web side of the ESP) I cannot find how to lit it automatically, based on the percentage of data read by the “co2”captor.
This must be running locally in the ESP, the lights must works even if the connection with HA is down. (for instance, I want to keep this device with me during my holydays).
As the command for the neopixelbus is not trivial, I found this that was working:
light:
- platform: neopixelbus
pin: GPIO12 #d6
variant: WS2812
num_leds: 1
effects:
- automation:
sequence:
- light.addressable_set:
red: 100%
green: 0%
blue: 0%
- automation:
sequence:
red: 100%
green: 100%
blue: 0%
- automation:
sequence:
red: 100%
green: 0%
blue: 0%
I know this IS ugly. I am definitely NOT a programmer; and by the way I am too old now.
With this code I can light my status led. A big step for me, but nothing for the humanity.
How would you write this code ???
I may add a particle sensor and one or two status led on the neopixel bus for the other sensors, but it won’t change anything.
thanks,
Benoit.
