In case of emergency I would like to send a Telegram message which door sensors of a door sensor group are open.
I managed to send all according device names of that group with the following code:
service: telegram_bot.send_message
message: >
Open sensors: {{" \n -"}} {{ expand('binary_sensor.door_sensors') |
selectattr('state', 'eq', 'on') | map(attribute='name') | list | join('\n')
target: -xxxxxxxxx
This works but I would like to attach the area_name
of each device too, so the output would be as follows:
Open sensors:
[deviceName] in [deviceArea]
Any idea on how to accomplish this?
Thanks in advance!
Open sensors: {% set doors = expand('binary_sensor.door_sensors')
| selectattr('state', 'eq', 'on') | list %}
{%- for door in doors %}
{{-" \n -"}}{{ door.name }} in {{ area_name(door.entity_id)}}
{%- endfor %}
Thanks man!
Is it also possible to add area aliases instead of area_name
itself?
AFAIK, aliases for areas are not currently directly accessible by templates. If you really want to use different names you can use a mapper approach in the message template or add a custom attribute to each of your door sensor entities.
For managing purposes and sharing stuff with this community I keep everything in english in the “backend”, which keeps everything consistent, maintainable and more understandable for others.
That’s the reason I have also set the main area names in english language and also numbered and not tied to a specific person (e.g. “TopFloor02_Bedroom03”).
Obviously this is confusing other family members, especially those which are not familiar with english language.
That’s the reason I want to make use of area name aliases, mainly for spreading helping informations to family members via Telegram.
Thanks for your help @Didgeridrew, I guess I will make a feature request on this.
I would recommend taking advantage of the new template macros to translate your area names to aliases.
{%- macro area_alias(area_name)%}
{%- set alias_map = {
'Living Room': 'la sala',
'Utility Room': 'el lavadero',
'Basement': 'el sĂłtano',
'Kitchen': 'la cocina'
{%- if area_name in alias_map -%}
{{- alias_map[area_name] }}
{%- else %}
{{ area_name }}
{%- endif %}
{%- endmacro%}
Then the template for the doors would be something like:
Puertas Abiertas: {% from 'YOUR_MACROS.jinja' import area_alias %}{% set doors = expand('binary_sensor.door_sensors')
{{-" \n -"}}{{ door.name }} en {{ area_alias(area_name(door.entity_id)) }}
{%- endfor %}
WOW! That worked like a charm, thank you so much mate, you don’t know how much you helped me
Edit: Unfortunately I could only send you a donation, but you should know that in addition I would shake your hand personally if I could
