I am trying to replicate how an Ikea remote and an Ikea color light bulb communicate via the Ikea Tradfri Bridge
This is what I got so far. If I push the middle button I get to toggle on/off the light bulb. If I short press the upper button, I get to move the brightness up 15 points on each press and if I long press, I get to move the brightness up continuously until I stop pressing. The opposite for the lower button.
Now for the left and right button, I checked the Ikea Tradfri app while pushing the buttons and it seems there are 20 color presets that I randomly cycle through whenever I press the left or right button. Of course if I press left once and then right once, I should be going back to the same color.
Now I was trying to figure out how to send the list of rgb values into a call service node. And you helped me with that (Hurray!!!), but I would want to figure out how to do the rest (make an array of arrays, cycle through it randomly (if possible, but not necessary), go back to the last color used (also if possible), and then send it to the call service for the color light bulb. ![:smiley: :smiley:](https://community.home-assistant.io/images/emoji/twitter/smiley.png?v=9)
These are the first 3 pairs as starters
234, 182, 62
239, 210, 118
241, 224, 181
I will try to use the info gave to see where it’s gonna take me ;))
[{"id":"5d7be55b.f6039c","type":"server-events","z":"7503cb14.1c6134","name":"","server":"3ed2660b.f6d8ba","event_type":"zha_event","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"waitForRunning":true,"x":310,"y":360,"wires":[["40f182d9.20278c"]]},{"id":"40f182d9.20278c","type":"switch","z":"7503cb14.1c6134","name":"Remote Commands","property":"payload.event.command","propertyType":"msg","rules":[{"t":"eq","v":"toggle","vt":"str"},{"t":"eq","v":"step_with_on_off","vt":"str"},{"t":"eq","v":"step","vt":"str"},{"t":"eq","v":"move_with_on_off","vt":"str"},{"t":"eq","v":"move","vt":"str"},{"t":"eq","v":"stop","vt":"str"},{"t":"eq","v":"press","vt":"str"},{"t":"eq","v":"hold","vt":"str"},{"t":"eq","v":"release","vt":"str"},{"t":"eq","v":"move_to_level_with_on_off","vt":"str"}],"checkall":"true","repair":false,"outputs":10,"x":320,"y":520,"wires":[["e12ab7d0.f3ebc8"],["b09c6110.5bd75"],["bfb6151c.7b4478"],["7a567951.447498","5676108d.f0dfd"],["bcf002be.218b3","5ef6a19f.a5bf9"],["3fbcd8d.43d8d28","ca7965f.8711b98"],["2b9a28b8.a5d628"],["636227e2.7d1ea8"],["3db29909.5835f6","8b943136.803fb"],[]],"info":"Normal presses\n\n1 Middle - toggle\n2 Up - step_with_on_off\n3 Down - step\n4 Left - press (args: 257, 13, 0)\nRight - press (args: 256, 13, 0)\n\n\nLong presses\n\n5, 6 Middle - toggle, then release then move_to_level_with_on_off, then press (arg 2, 0, 0)\n\n7 Up - move_with_on_off and then stop (when unpressing the button)\n\n8, 9 Down - move and then stop (when unpressing the button)\n\n10 Left - hold (args: 3329, 0) and then release (arg: 3742)\n\nRight - hold (args: 3328, 0) and then release (arg: 2696)\n\n\n\n\n1 toggle\n2 step_with_on_off\n3 step\n7 move_with_on_off\n8 move\n9 stop\n4 press\n10 hold\n5 release\n6 move_to_level_with_on_off\n\n"},{"id":"416c3892.19a9f8","type":"inject","z":"7503cb14.1c6134","name":"on","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"on","payloadType":"str","x":370,"y":660,"wires":[["8b53bc2a.fb39f"]]},{"id":"a736255f.2d2278","type":"inject","z":"7503cb14.1c6134","name":"off","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"off","payloadType":"str","x":370,"y":700,"wires":[["2bf65be1.e30844"]]},{"id":"8b53bc2a.fb39f","type":"api-call-service","z":"7503cb14.1c6134","name":"Turn ON Light","server":"3ed2660b.f6d8ba","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.lab_color_bulb","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1260,"y":520,"wires":[["f144fb51.2307d8"]]},{"id":"2bf65be1.e30844","type":"api-call-service","z":"7503cb14.1c6134","name":"Turn OFF Light","server":"3ed2660b.f6d8ba","version":1,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.lab_color_bulb","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1260,"y":580,"wires":[["f144fb51.2307d8"]]},{"id":"c5594516.62d738","type":"function","z":"7503cb14.1c6134","name":"Brightness up","func":"// add actual brightness value\nvar brightness = msg.data.attributes.brightness;\n\nbrightness = brightness + 15;\n \n\nif(brightness >= 255){\n brightness = 254;\n }\n \nif(brightness < 0){\n brightness = 0;\n\t} \n \nmsg.data.attributes.brightness = brightness\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":980,"y":640,"wires":[["c3ceaec4.05648"]],"info":"min brightness 0\nmax brightness 255\n\nmin color_temp 0 \nmax color_temp 250"},{"id":"392c2534.62f7aa","type":"api-current-state","z":"7503cb14.1c6134","name":"Light State","server":"3ed2660b.f6d8ba","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.lab_color_bulb","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":790,"y":640,"wires":[["c5594516.62d738"]]},{"id":"5f79d746.ba18c8","type":"function","z":"7503cb14.1c6134","name":"Brightness down","func":"// add actual brightness value\nvar brightness = msg.data.attributes.brightness;\n\nbrightness = brightness - 15;\n \n\nif(brightness >= 255){\n brightness = 254;\n }\n \nif(brightness < 1){\n brightness = 1;\n\t} \n \nmsg.data.attributes.brightness = brightness\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1000,"y":700,"wires":[["c3ceaec4.05648"]],"info":"min brightness 0\nmax brightness 255\n\nmin color_temp 0 \nmax color_temp 250"},{"id":"fd53b136.0f8d4","type":"api-current-state","z":"7503cb14.1c6134","name":"Light State","server":"3ed2660b.f6d8ba","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.lab_color_bulb","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":790,"y":700,"wires":[["5f79d746.ba18c8"]]},{"id":"c3ceaec4.05648","type":"api-call-service","z":"7503cb14.1c6134","name":"Light Brightness","server":"3ed2660b.f6d8ba","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.lab_color_bulb","data":"{ \"brightness\": {{data.attributes.brightness}}, \"rgb_color\": {{data.attributes.rgb_color}} }","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1260,"y":640,"wires":[["872dfdd2.ac1e8"]],"info":"{\"brightness\": {{data.attributes.brightness}}}"},{"id":"122f5e5a.528e42","type":"inject","z":"7503cb14.1c6134","name":"brightness up","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"bang","payloadType":"str","x":350,"y":760,"wires":[["b09c6110.5bd75"]]},{"id":"7befef54.a0fe8","type":"inject","z":"7503cb14.1c6134","name":"brightness down","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"bang","payloadType":"str","x":340,"y":800,"wires":[["bfb6151c.7b4478"]]},{"id":"e959ed01.4977f","type":"api-current-state","z":"7503cb14.1c6134","name":"Light State","server":"3ed2660b.f6d8ba","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.lab_color_bulb","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":790,"y":780,"wires":[["b732e44b.522c08"]]},{"id":"b732e44b.522c08","type":"function","z":"7503cb14.1c6134","name":"Brightness up (continous)","func":"// add actual brightness value\nvar brightness = msg.data.attributes.brightness;\n\nbrightness = brightness + 15;\n \n\nif(brightness >= 255){\n brightness = 254;\n }\n \nif(brightness < 0){\n brightness = 0;\n\t} \n \nmsg.data.attributes.brightness = brightness\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1010,"y":780,"wires":[["c3ceaec4.05648","b9b9e9cf.ebe548"]],"info":"min brightness 0\nmax brightness 255\n\nmin color_temp 0 \nmax color_temp 250"},{"id":"b9b9e9cf.ebe548","type":"delay","z":"7503cb14.1c6134","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1270,"y":780,"wires":[["7c61ace6.58ea64"]]},{"id":"7c61ace6.58ea64","type":"gate","z":"7503cb14.1c6134","name":"","controlTopic":"control","defaultState":"open","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","persist":false,"x":1450,"y":780,"wires":[["e959ed01.4977f"]]},{"id":"3fbcd8d.43d8d28","type":"change","z":"7503cb14.1c6134","name":"close","rules":[{"t":"set","p":"payload","pt":"msg","to":"close","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1290,"y":700,"wires":[["7c61ace6.58ea64"]]},{"id":"52cf825b.58ea6c","type":"inject","z":"7503cb14.1c6134","name":"open","props":[{"p":"payload","v":"open","vt":"str"},{"p":"topic","v":"control","vt":"string"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"control","payload":"open","payloadType":"str","x":1450,"y":700,"wires":[["7c61ace6.58ea64"]]},{"id":"80c6f7a4.645af8","type":"inject","z":"7503cb14.1c6134","name":"close","props":[{"p":"payload","v":"close","vt":"str"},{"p":"topic","v":"control","vt":"string"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"control","payload":"close","payloadType":"str","x":1450,"y":740,"wires":[["7c61ace6.58ea64"]]},{"id":"7a567951.447498","type":"change","z":"7503cb14.1c6134","name":"open","rules":[{"t":"set","p":"payload","pt":"msg","to":"open","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1290,"y":740,"wires":[["7c61ace6.58ea64"]]},{"id":"b0d76094.de4f","type":"inject","z":"7503cb14.1c6134","name":"brightness up (cont.)","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"bang","payloadType":"str","x":330,"y":900,"wires":[["7a567951.447498","5676108d.f0dfd"]]},{"id":"dee30c28.e5fdf","type":"inject","z":"7503cb14.1c6134","name":"brightness stop","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"bang","payloadType":"str","x":340,"y":860,"wires":[["3fbcd8d.43d8d28","ca7965f.8711b98"]]},{"id":"872dfdd2.ac1e8","type":"debug","z":"7503cb14.1c6134","name":"light brightness","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1460,"y":640,"wires":[]},{"id":"f144fb51.2307d8","type":"debug","z":"7503cb14.1c6134","name":"light on/off","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1450,"y":520,"wires":[]},{"id":"6cc68035.f2b4f","type":"api-current-state","z":"7503cb14.1c6134","name":"Light State","server":"3ed2660b.f6d8ba","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.lab_color_bulb","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":790,"y":920,"wires":[["641611f3.c4328"]]},{"id":"641611f3.c4328","type":"function","z":"7503cb14.1c6134","name":"Brightness down (continous)","func":"// add actual brightness value\nvar brightness = msg.data.attributes.brightness;\n\nbrightness = brightness - 15;\n \n\nif(brightness >= 255){\n brightness = 254;\n }\n \nif(brightness < 0){\n brightness = 0;\n\t} \n \nmsg.data.attributes.brightness = brightness\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1000,"y":920,"wires":[["d28c63b4.e75fa","c3ceaec4.05648"]],"info":"min brightness 0\nmax brightness 255\n\nmin color_temp 0 \nmax color_temp 250"},{"id":"d28c63b4.e75fa","type":"delay","z":"7503cb14.1c6134","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1270,"y":920,"wires":[["f162388f.fec128"]]},{"id":"f162388f.fec128","type":"gate","z":"7503cb14.1c6134","name":"","controlTopic":"control","defaultState":"open","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","persist":false,"x":1450,"y":920,"wires":[["6cc68035.f2b4f"]]},{"id":"ca7965f.8711b98","type":"change","z":"7503cb14.1c6134","name":"close","rules":[{"t":"set","p":"payload","pt":"msg","to":"close","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1290,"y":840,"wires":[["f162388f.fec128"]]},{"id":"1b89e3cd.7cde0c","type":"inject","z":"7503cb14.1c6134","name":"open","props":[{"p":"payload","v":"open","vt":"str"},{"p":"topic","v":"control","vt":"string"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"control","payload":"open","payloadType":"str","x":1450,"y":840,"wires":[["f162388f.fec128"]]},{"id":"f996addd.7811","type":"inject","z":"7503cb14.1c6134","name":"close","props":[{"p":"payload","v":"close","vt":"str"},{"p":"topic","v":"control","vt":"string"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"control","payload":"close","payloadType":"str","x":1450,"y":880,"wires":[["f162388f.fec128"]]},{"id":"bcf002be.218b3","type":"change","z":"7503cb14.1c6134","name":"open","rules":[{"t":"set","p":"payload","pt":"msg","to":"open","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1290,"y":880,"wires":[["f162388f.fec128"]]},{"id":"2bc0dcde.20e164","type":"inject","z":"7503cb14.1c6134","name":"brightness down (cont.)","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"bang","payloadType":"str","x":320,"y":940,"wires":[["bcf002be.218b3","5ef6a19f.a5bf9"]]},{"id":"b5620a4d.3ea0c8","type":"comment","z":"7503cb14.1c6134","name":"Brightness","info":"","x":580,"y":580,"wires":[]},{"id":"b09c6110.5bd75","type":"api-call-service","z":"7503cb14.1c6134","name":"Turn ON Light","server":"3ed2660b.f6d8ba","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.lab_color_bulb","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":600,"y":640,"wires":[["392c2534.62f7aa"]]},{"id":"bfb6151c.7b4478","type":"api-call-service","z":"7503cb14.1c6134","name":"Turn ON Light","server":"3ed2660b.f6d8ba","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.lab_color_bulb","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":600,"y":700,"wires":[["fd53b136.0f8d4"]]},{"id":"5676108d.f0dfd","type":"api-call-service","z":"7503cb14.1c6134","name":"Turn ON Light","server":"3ed2660b.f6d8ba","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.lab_color_bulb","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":600,"y":780,"wires":[["e959ed01.4977f"]]},{"id":"5ef6a19f.a5bf9","type":"api-call-service","z":"7503cb14.1c6134","name":"Turn ON Light","server":"3ed2660b.f6d8ba","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.lab_color_bulb","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":600,"y":920,"wires":[["6cc68035.f2b4f"]]},{"id":"e12ab7d0.f3ebc8","type":"api-call-service","z":"7503cb14.1c6134","name":"Light Toggle","server":"3ed2660b.f6d8ba","version":1,"debugenabled":false,"service_domain":"light","service":"toggle","entityId":"light.lab_color_bulb","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1250,"y":460,"wires":[["1572e956.47cea7"]]},{"id":"1572e956.47cea7","type":"debug","z":"7503cb14.1c6134","name":"light toggle","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1450,"y":460,"wires":[]},{"id":"6991393c.28a9e8","type":"inject","z":"7503cb14.1c6134","name":"light toggle","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"bang","payloadType":"str","x":360,"y":620,"wires":[["e12ab7d0.f3ebc8"]]},{"id":"6b744a99.331bb4","type":"function","z":"7503cb14.1c6134","name":"Color Switch Left","func":"msg.payload = {\n domain: \"light\",\n service: \"turn_on\",\n data: {\n entity_id: \"light.lab_color_bulb\",\n rgb_color: msg.data.attributes.rgb_color\n }\n};\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":990,"y":1040,"wires":[["754568a7.1ee2d8"]],"info":"min brightness 0\nmax brightness 255\n\nmin color_temp 0 \nmax color_temp 250"},{"id":"290bf86c.154fc8","type":"function","z":"7503cb14.1c6134","name":"Color Switch Right","func":"\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":990,"y":1160,"wires":[["754568a7.1ee2d8"]],"info":"min brightness 0\nmax brightness 255\n\nmin color_temp 0 \nmax color_temp 250"},{"id":"9c611585.784688","type":"api-current-state","z":"7503cb14.1c6134","name":"Light State","server":"3ed2660b.f6d8ba","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.lab_color_bulb","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":790,"y":1160,"wires":[["290bf86c.154fc8"]]},{"id":"7dc4784b.6f2608","type":"inject","z":"7503cb14.1c6134","name":"color switch left","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"bang","payloadType":"str","x":340,"y":1140,"wires":[["301221b9.b1bf8e"]]},{"id":"e206a6b6.416668","type":"inject","z":"7503cb14.1c6134","name":"color switch right","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"bang","payloadType":"str","x":340,"y":1200,"wires":[["2f0e3533.aa549a"]]},{"id":"2f0e3533.aa549a","type":"api-call-service","z":"7503cb14.1c6134","name":"Turn ON Light","server":"3ed2660b.f6d8ba","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.lab_color_bulb","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":600,"y":1160,"wires":[["9c611585.784688"]]},{"id":"ceb52def.1c308","type":"comment","z":"7503cb14.1c6134","name":"Color Switch","info":"Ikea Tradfri Bridge and App offer the possibility to switch between a set of colors. So we replicate that here.\n\nThis is the list of the 20 RGB values pairs","x":590,"y":980,"wires":[]},{"id":"84a95494.728308","type":"api-current-state","z":"7503cb14.1c6134","name":"Light State","server":"3ed2660b.f6d8ba","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.lab_color_bulb","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":790,"y":1240,"wires":[["95bf648d.3d3bf8"]]},{"id":"95bf648d.3d3bf8","type":"function","z":"7503cb14.1c6134","name":"Color Switch Left (continous)","func":"\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1020,"y":1240,"wires":[["ebcd13f5.ca897","754568a7.1ee2d8"]],"info":"min brightness 0\nmax brightness 255\n\nmin color_temp 0 \nmax color_temp 250"},{"id":"ebcd13f5.ca897","type":"delay","z":"7503cb14.1c6134","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1270,"y":1240,"wires":[["52352259.3c9f1c"]]},{"id":"52352259.3c9f1c","type":"gate","z":"7503cb14.1c6134","name":"","controlTopic":"control","defaultState":"open","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","persist":false,"x":1450,"y":1240,"wires":[["84a95494.728308"]]},{"id":"3db29909.5835f6","type":"change","z":"7503cb14.1c6134","name":"close","rules":[{"t":"set","p":"payload","pt":"msg","to":"close","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1290,"y":1160,"wires":[["52352259.3c9f1c"]]},{"id":"10f966ff.ecdb59","type":"inject","z":"7503cb14.1c6134","name":"open","props":[{"p":"payload","v":"open","vt":"str"},{"p":"topic","v":"control","vt":"string"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"control","payload":"open","payloadType":"str","x":1450,"y":1160,"wires":[["52352259.3c9f1c"]]},{"id":"a81ce50.89cc618","type":"inject","z":"7503cb14.1c6134","name":"close","props":[{"p":"payload","v":"close","vt":"str"},{"p":"topic","v":"control","vt":"string"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"control","payload":"close","payloadType":"str","x":1450,"y":1200,"wires":[["52352259.3c9f1c"]]},{"id":"7714f2db.6199ac","type":"change","z":"7503cb14.1c6134","name":"open","rules":[{"t":"set","p":"payload","pt":"msg","to":"open","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1290,"y":1200,"wires":[["52352259.3c9f1c"]]},{"id":"1699fcd7.036323","type":"inject","z":"7503cb14.1c6134","name":"color switch left (cont.)","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"bang","payloadType":"str","x":320,"y":1300,"wires":[["7714f2db.6199ac","962699a1.9df568"]]},{"id":"d4b09b6a.a69aa8","type":"inject","z":"7503cb14.1c6134","name":"color switch stop","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"bang","payloadType":"str","x":340,"y":1260,"wires":[["8b943136.803fb","3db29909.5835f6"]]},{"id":"1b1aa9b3.4c43a6","type":"api-current-state","z":"7503cb14.1c6134","name":"Light State","server":"3ed2660b.f6d8ba","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.lab_color_bulb","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":790,"y":1380,"wires":[["ea67884b.b152f8"]]},{"id":"ea67884b.b152f8","type":"function","z":"7503cb14.1c6134","name":"Color Switch Right (continous)","func":"\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1010,"y":1380,"wires":[["45f78569.cfc09c","754568a7.1ee2d8"]],"info":"min brightness 0\nmax brightness 255\n\nmin color_temp 0 \nmax color_temp 250"},{"id":"45f78569.cfc09c","type":"delay","z":"7503cb14.1c6134","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1270,"y":1380,"wires":[["556655f6.96b7bc"]]},{"id":"556655f6.96b7bc","type":"gate","z":"7503cb14.1c6134","name":"","controlTopic":"control","defaultState":"open","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","persist":false,"x":1450,"y":1380,"wires":[["1b1aa9b3.4c43a6"]]},{"id":"8b943136.803fb","type":"change","z":"7503cb14.1c6134","name":"close","rules":[{"t":"set","p":"payload","pt":"msg","to":"close","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1290,"y":1300,"wires":[["556655f6.96b7bc"]]},{"id":"7dca0d46.f243a4","type":"inject","z":"7503cb14.1c6134","name":"open","props":[{"p":"payload","v":"open","vt":"str"},{"p":"topic","v":"control","vt":"string"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"control","payload":"open","payloadType":"str","x":1450,"y":1300,"wires":[["556655f6.96b7bc"]]},{"id":"13ebf9cc.579116","type":"inject","z":"7503cb14.1c6134","name":"close","props":[{"p":"payload","v":"close","vt":"str"},{"p":"topic","v":"control","vt":"string"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"control","payload":"close","payloadType":"str","x":1450,"y":1340,"wires":[["556655f6.96b7bc"]]},{"id":"348462b6.16bdee","type":"change","z":"7503cb14.1c6134","name":"open","rules":[{"t":"set","p":"payload","pt":"msg","to":"open","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1290,"y":1340,"wires":[["556655f6.96b7bc"]]},{"id":"25746a05.125116","type":"inject","z":"7503cb14.1c6134","name":"color switch right (cont.)","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"bang","payloadType":"str","x":320,"y":1340,"wires":[["348462b6.16bdee","f805bf5.cd4c64"]]},{"id":"962699a1.9df568","type":"api-call-service","z":"7503cb14.1c6134","name":"Turn ON Light","server":"3ed2660b.f6d8ba","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.lab_color_bulb","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":600,"y":1240,"wires":[["84a95494.728308"]]},{"id":"f805bf5.cd4c64","type":"api-call-service","z":"7503cb14.1c6134","name":"Turn ON Light","server":"3ed2660b.f6d8ba","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.lab_color_bulb","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":600,"y":1380,"wires":[["1b1aa9b3.4c43a6"]]},{"id":"2b9a28b8.a5d628","type":"switch","z":"7503cb14.1c6134","name":"Remote Commands","property":"payload.event.args[0]","propertyType":"msg","rules":[{"t":"eq","v":"257","vt":"str"},{"t":"eq","v":"256","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":320,"y":1020,"wires":[["301221b9.b1bf8e"],["2f0e3533.aa549a"]],"info":"Normal presses\n\n1 Middle - toggle\n2 Up - step_with_on_off\n3 Down - step\n4 Left - press (args: 257, 13, 0)\nRight - press (args: 256, 13, 0)\n\n\nLong presses\n\n5, 6 Middle - toggle, then release then move_to_level_with_on_off, then press (arg 2, 0, 0)\n\n7 Up - move_with_on_off and then stop (when unpressing the button)\n\n8, 9 Down - move and then stop (when unpressing the button)\n\n10 Left - hold (args: 3329, 0) and then release (arg: 3742)\n\nRight - hold (args: 3328, 0) and then release (arg: 2696)\n\n\n\n\n1 toggle\n2 step_with_on_off\n3 step\n4 press\n5 release\n6 move_to_level_with_on_off\n7 move_with_on_off\n8 move\n9 stop\n10 hold\n"},{"id":"636227e2.7d1ea8","type":"switch","z":"7503cb14.1c6134","name":"Remote Commands","property":"payload.event.command.args","propertyType":"msg","rules":[{"t":"eq","v":"3329","vt":"str"},{"t":"eq","v":"3328","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":300,"y":1400,"wires":[["962699a1.9df568"],["f805bf5.cd4c64"]],"info":"Normal presses\n\n1 Middle - toggle\n2 Up - step_with_on_off\n3 Down - step\n4 Left - press (args: 257, 13, 0)\nRight - press (args: 256, 13, 0)\n\n\nLong presses\n\n5, 6 Middle - toggle, then release then move_to_level_with_on_off, then press (arg 2, 0, 0)\n\n7 Up - move_with_on_off and then stop (when unpressing the button)\n\n8, 9 Down - move and then stop (when unpressing the button)\n\n10 Left - hold (args: 3329, 0) and then release (arg: 3742)\n\nRight - hold (args: 3328, 0) and then release (arg: 2696)\n\n\n\n\n1 toggle\n2 step_with_on_off\n3 step\n4 press\n5 release\n6 move_to_level_with_on_off\n7 move_with_on_off\n8 move\n9 stop\n10 hold\n"},{"id":"301221b9.b1bf8e","type":"api-call-service","z":"7503cb14.1c6134","name":"Turn ON Light","server":"3ed2660b.f6d8ba","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.lab_color_bulb","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":600,"y":1040,"wires":[["77e09144.04c91"]]},{"id":"e842f2b4.64dd8","type":"comment","z":"7503cb14.1c6134","name":"Remote for lab color bulb","info":"","x":330,"y":420,"wires":[]},{"id":"77e09144.04c91","type":"api-current-state","z":"7503cb14.1c6134","name":"Light State","server":"3ed2660b.f6d8ba","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.lab_color_bulb","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":790,"y":1040,"wires":[["6b744a99.331bb4"]]},{"id":"754568a7.1ee2d8","type":"api-call-service","z":"7503cb14.1c6134","name":"Light Brightness","server":"3ed2660b.f6d8ba","version":1,"debugenabled":false,"service_domain":"","service":"","entityId":"","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1200,"y":1040,"wires":[[]],"info":"{\"brightness\": {{data.attributes.brightness}}}"},{"id":"3ed2660b.f6d8ba","type":"server","z":"","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
![119768992_10159308890505961_6891577429410263801_n](https://community-assets.home-assistant.io/original/3X/e/b/eb51436e169f984f97005d502e6ea7060d35d27e.jpeg)
