I made a version that uses conditions:
will a generic binary sensor work? I made a version that uses any binary sensor:
@DeimicUser
This may be closer to what you wanted:
Thank you! Iâll give it a try asap!
Hey, I went through all the replies and didnt find any solution that would work
The automation used to work perfectly on my HA app on my iPhone and now when im connected to local URL I only get a small preview of the snapshot and when i tap and hold on the notification a large snapshot no longer appears. AND when im connected to an external URL, I only get a text notification without even the small preview of the snapshot. Both used to work with both the preview and a large snapshot appearing after tap and holding on the notification. Also used to work on my apple watch. Is there a fix? Nothing changed in my HA as far as i know. Thanks!!
also - for some reason with this automation (đ¸ Notification with camera snapshot with blocking condition and clickaction) when on local i can at least do the tap and hold to see the larger snapshot⌠really strange - with this automation only the external doesnt work (at all, not even the small preview image)
Hey, how do I send the notification to several devices?
I should modify the blueprint? And create a group of devices? What if itâs a mix of ios and android devices?
This blueprint has started to spam my logs:
Template variable warning: 'None' has no attribute 'object_id' when rendering '/config/www/tmp/snapshot_{{ states[camera].object_id }}.jpg'
When run manually (or automatically) it works just fine. Anyone got any ideas?
I believe my blueprint would work for you, added the ability for notification groups recently!
Hi, Thank you for the blueprint script. It is working fine.
Iâm newbie on HA, my question is just a support about the following issue.
How can I integrate condition to that blueprint script, example, send me the snapshot notification only when I.m out of Home zone.
Can you help me ?
Thanks a lot
see my blueprint:
For me a tap opens HA but a long press pulls up the notification settings (default/silent)
Thank you so much for this Steven! I was banging my head against the wall, wondering why I could see the snapshot_cameraname.jpg file in the Terminal integration on my Home Assistant Green (in root/config/www/tmp) but I couldnât view it at http://homeassistant.local:8123/local/tmp/snapshot_cameraname.jpg. I was getting the notifications on my iPhone but they had no image - just a 404 message.
Then I saw your advice to restart Home Assistant. It worked a treat. The image was visible in my browser and the notifications work as intended!
Many thanks for providing the blueprint.
It has been working great recently, however I started collecting many snapshots which I couldnât find how to delete them. Does anyone knows how to do that? Currently, all the snapshots are saved in Media>Nest (since I have google nest Doorbell).
Many thanks in advance
First setup a shell command in your configuration.yaml file:
shell_command:
delete_old_jpg_files: 'find /config/www/location -name "*.jpg" -type f -mtime +30 -exec rm {} \;'
Change the âlocationâ to the folder in which your jpg files reside. Then create an automation that will trigger the shell.
alias: Delete old gate jpg if older then 30 days
description: ""
mode: single
triggers:
- at: "02:00:00"
trigger: time
conditions: []
actions:
- action: shell_command.delete_old_jpg_files
data: {}
The shell command will delete all files equal to and older than 30 days in the location you specify. The automation executes that shell every morning at 2am.
Thank you for your response.
I followed your instructions and the files are there after the automation has ran.
I went the developers tools â Actions, then chose âShell Command: delete_old_jpg_filesâ and I got the below Response:
stdout: ââ
stderr: >-
find: /config/www/media/Nest/Entrance Door doorbell: Recent Events/: No such
file or directory
returncode: 1
Knowing that I am sure of the path of the files, they are in:
Media â Nest â Entrance Door doorbell: Recent Events
Thanks for the blueprint.
I want to have some extra conditions added to it. How do I do that ?
I only want it active in the weekend
Possible to add Multiple devices (android & ios)?
If not, maybe someone knows an alternative blueprint? thanks
Thanks for this blueprint.
I have it working using blink cameras for motion then taking a snap shot on my hikvision.
There seems to be a long delay any ideas where the delay would be?
When I hit test on the blueprint it comes through almost instantly.
A
I have been using this blue print for a while. It works great. I am now integrating Google Generative AI and want to add a description when it send me a picture. Is this possible and where do I put the code? Thanks
Same question.
pls let us know if you find a solution.
Thanks for the blueprint, Its taken me a while but i have it working correctly now. My question is, is there a delay i can place maybe in the YAML to delay the next notification. For example there will be motion detected and the automation runs but will send me 3+ notifcations as that Binary sensor has been active for a while. Im thinking something like "Delay next process for 2 minutes or something to that affect.
