📸 Send camera snapshot notification on motion
This blueprint will send a snapshot from a camera to your phone when motion is detected.
Blueprint
Click the badge to import this Blueprint: (needs Home Assistant Core 2021.3 or higher)
Or import this Blueprint by using the forum topic URL:
blueprint:
  name: Send a camera snapshot when motion is detected
  description: >
    This automation blueprint creates a camera snapshot if motion is detected
    and sends a notification to your phone with the picture.
  domain: automation
  input:
    motion_sensor:
      description: The sensor wich triggers the snapshot creation
      selector:
          entity:
            domain: binary_sensor
            device_class: motion
    camera:
      description: The camera which creates the snapshot
      selector:
        entity:
          domain: camera
    notify_device:
      name: Device to notify
      description: Device needs to run the official Home Assistant app to receive notifications
      selector:
        device:
          integration: mobile_app
    is_ios:
      name: Is it an iOS device?
      description: Toggle if your selected device runs iOS, default is Android
      selector:
        boolean:
      default: false
    notification_title:
      name: Notification title (Optional)
      description: 'Default: "Motion detected!"'
      default: "Motion detected!"
    notification_message:
      name: Notification message (Optional)
      description: 'Default: "{{ motion_sensor_name }} detected movement!"'
      default: "{{ motion_sensor_name }} detected movement!"
    delay:
      name: Delay (Optional)
      description: Wait before creating camera snapshot
      default: ""
      selector:
        number:
            min: 0
            max: 60
            unit_of_measurement: seconds
            mode: slider
  platform: state
  entity_id: !input motion_sensor
  to: "on"
variables:
  motion_sensor: !input motion_sensor
  motion_sensor_name: "{{ states[motion_sensor].name }}"
  camera: !input camera
  notify_device: !input notify_device
  is_ios: !input is_ios
  notification_title: !input notification_title
  notification_message: !input notification_message
  delay: !input delay
  snapshot_create_file_path: "/config/www/tmp/snapshot_{{ states[camera].object_id }}.jpg"
  snapshot_access_file_path: "{{ snapshot_create_file_path | replace('/config/www','/local') }}"
  - delay: "{{ delay }}"
  - service: camera.snapshot
    entity_id: !input camera
      filename: "{{ snapshot_create_file_path }}"
  - device_id: !input notify_device
    domain: mobile_app
    type: notify
    title: "{{ notification_title }}"
    message: "{{ notification_message }}"
    data: >
      {% set android_data = {"image": "%s"} | format(snapshot_access_file_path) %}
      {% set ios_data = {"attachment": {"url": "%s", "content_type": "JPEG"}} | format(snapshot_access_file_path) %}
      {{ ios_data if is_ios else android_data }}
📸 Notification with camera snapshot with blocking condition and clickaction
Send Synology Surveillance motion events to HA switch
Merge persistent notifications and mobile app notifications
Custom Component: Unifi Protect
Home Assistant update notification
Send camera snapshot notification with Frenck’s doorbell
Taking snapshot from a camera does not work
Motioneye motion notification with image
🔔 Notifications - Actionable Mobile Notifications Script, with optional Timeout Feature and Camera Snapshots [works with iOS/Android]
Ring Device integration via MQTT w/ Video Streaming
Send notification on (motion, doorbell ring, person detected) [Reolink PoE doorbell]
Help with mobile notifications
Snapshot from ezviz camera when doorbell go’s
Camera - Send & Save snapshot to mobile device when motion is detected with Conditions. Now with Custom Triggers!
Yet Another Notification Template: a Newbie's Journey
Notification lost when tapping them
Community Highlights: 11th edition
[Custom Component] Tapo: Cameras Control
Snapshot Issue in iOS Actionable Notifications
Is it possible to convert blueprint to automation?
Is there a way to include a still image (from doorbell camera) with a notification from HA to my iPhone?
Automation NOT working. :(
Question about mobile notifications
Vivotek motion detection notification
Camera Motion Detection Screenshot
DIY $23-55 alternative to MyQ
How to track what automation (or something else) disabled the automation?
Automation enable/disable based on entity state(s)
Hikvision line detection binary sensor not detected
Surveillance camera (Lupus LE228) Snapshot
I get the following error when trying to import:
while scanning an anchor in “”, line 3, column 16: description: > ^ expected alphabetic or numeric character, but found ‘;’ in “”, line 3, column 19: description: > ^
This is interesting. I can import it without any issues.
Are you using the latest beta?
This URL works for me: https://community.home-assistant.io/t/send-camera-snapshot-notification-on-motion/254565
Ah no, let me update. But I did import another blueprint tho
Update fixed it thanks
Nice workaround for the inconsistency in Android / iOS mobile app notifications, really clever idea!
There’s a problem with line 80, you have a hardcoded camera.demo_camera entity id that was probably mistakenly left over from when you were testing. It should be entity_id: !input camera
Thank you very much!
I don’t have an iOS device, so I couldn’t test it, but according to the documentation it should work :slightly_smiling_face::crossed_fingers:
I did left the camera.demo_camera there accidentally. Now it’s fixed. Thank you again.
It would be nice to specify the save path on the snapshot. I currently do this but I store it in the /media/folder/last_motion.jpg so you can use the media viewer. I also store it in a secondary archive folder so you have history (/media/folder/archive/%date%.jpg) but that seems like a different blueprint.
Sadly, I couldn’t select any of my Aeotec motion sensors. They are not binary_sensors, but rather sensors sending a 0, 3, or 8 for no motion, Accel, and Motion respectively.
You could create a template sensor to make it report 1 if the value is different from 0 and then use that sensor in the blueprint
Would this also work for a button? I would like to hook my doorbell to send a snapshot.
Trying to find the best way to do this.
You could edit the blueprint and change the “motion_sensor” part to make it point to a binary sensor or whatever your doorbell shows up as, everything else should be the same if you have a camera device to get the snapshot from
Just remove line 14 (device_class: motion) and it might just work
Thank you for this!
Thanks, this indeed showed my button. Unfortunately this doesn’t make the template work. Because my button is changing from ‘off’ to ‘Single’ or ‘Double’ I think it needs an ‘On’ or ‘Off’ at least with a motion sensor it works. But with the button it does not.
I guess your button isn’t a binary_sensor then
You could create a template_sensor for it and that would fix it
Quick mockup:
sensor
    sensors:
      someone_at_the_door:
        value_template: >
          {% if (is_state('switch.yourbuttonhere', 'single') or is_state('switch.yourbuttonhere', 'double'))  %}
            on
          {% else %}
            off
          {% endif %}
Thank you, I’ve made the template sensor. But I just checked and the Xiaomi states never change. The state is always ‘Off’ . It does however give this :
last_action: double
voltage: 3.02
battery_level: 45
friendly_name: Boven 1
Thanks for all the help already, but it seems I have to dive in a little more. Just started with Home Assistant and getting to understand automations better is something I will try to figure out more during the holidays.
I see the problem, your “single” or “double” value isn’t the status but an attribute
Replace is_state('switch.yourbuttonhere', 'single') with is_state_attr('switch.yourbuttonhere','last_action','single') and do the same for double, it should work the
Also you can test that part in HA by click Developer Tools and then Template, you can paste the value_template part in there and see if it returns what you’re expecting
Waw love this blueprint. (Or is it perhaps blueprint on general that I like???)
Anyway thanks for this one
Some changes I have made to in in my version :
-other devices as trigger - Nest doorbell button push worls sweet
-ios critical alert : so it works even when my phone is silent (which it is 99% of the time - the wonders world of the watch :slight_smile: )
Any way I can contribute to your without polluting the blueprint market woth simular blueprints
can you add a condition? for example i have an input Boolean if the house is in away mode. can you add a condition if i am away send snapshot if motion.
I like this idea, but I think it is a different blueprint. I wanted to keep this simple, and not fill the user’s SD cards with the snapshots, so that is why I rejected my first idea to include the date in the file name. I choose to save the snapshots to the www folder, because it does not require additional configuration. (media_dirs needs to be set up beforehand)
