Send command from Windows command line to HA?
Hey! I am a new user on HA.
I wonder if there is a way to send commands to HA from Windows command line? For example, send a command to enable or disable a power switch (On/Off).
/ P
hass-cli (https://www.home-assistant.io/blog/2019/02/04/introducing-home-assistant-cli/) is an option. You’ll need to install Python on the Windows machine.
Thank you Jcuccia!
I think that is what i need! :smiley:
/P
Another alternative would be to install an MQTT client on Windows. Mosquitto is the most common.
Thank you rwpalmer
I will check this out too!
/p
