Send data to ESP32?
Hi
I have a couple of ESP32’s set up with some BLE sensors and exposing them to HA. All nice.
I had the idea that I would like to send some sensor data from HA to the ESP32, so that it could pass it on to a display. How do I start going about to do that? Is there some sort of ESPHome sensor pre-defined which can take HA data as input?
My basic idea is to collect data from my Xiaomi BLE sensors, process it into some kind of average/get temperature from a local weather forecast and display it on the Xiaomi LCD using a modified firmware:
ATC_MiThermometer/BLE_term_lcd.ino at master · pvvx/ATC_MiThermometer (github.com)
Thanks!
The easiest way is to expose a service from the ESP that you can call in Home Assistant:
https://esphome.io/components/sensor/homeassistant.html and https://esphome.io/components/text_sensor/homeassistant.html and this example https://esphome.io/cookbook/display_time_temp_oled.html
