Hi there, is there any way for Home Assistant to send an Google Assistant command to a specific device?
Maybe to trigger a device which is not accessible via Home Assistant or to trigger a specific Google Assistant device to change the alarm?
There is no way to send a command to a specific device as far as I am aware anyway.
However in your first example of triggering a device that HA does not have access or control over then yes there options as in this case scenario you don’t need to specify or send the command to a specific device as any device will be able to action that request as long as the google command sent includes the room name.
In this case I would recommend you take a look at:
It’s not maintained anymore but still works a treat.
Thanks, I´ve tried this but doesn´t got it to work, so I thought it´s because it´s deprecated.
It’s no longer maintained but still works perfectly
