Send KNX telegram with system startup
Hi!
I use the KNX integration of Home Assistant
Is it possible to send a telegram at system startup so that I can query my Telenot alarm system
The telegram should be sent at every restart because the query of telegrams states is not possible directly
Hi :wave:!
You can use the homeassistant trigger
and knx.send action for that.
