This blueprint monitors a group of network devices and sends a notification message to a specified mobile app if and when a device from the group loses network connectivity.
Get started
Click the badge to import this Blueprint: (needs Home Assistant Core 2021.3 or higher)
Or import this Blueprint by using the forum topic / Gist URL:
The devices to be monitored are organised in a group, e.g. like this (in groups.yaml):
Replace "abc", "xyz" and "aa.bb.cc.dd", "ww.xx.yy.zz", respectively, with the names and hostnames/IP addresses of your network devices to be monitored.
What´s the advantage of this blueprint compared to a manual automation when having network devices already available as device_tracker entities e. g. by router integration (so not based on ping sensors)?
Don´t all those ping sensors put additional (but of course minimal) traffic to the network and devices?
Anyway I guess nice and pretty helpful especially for beginners without any existing “network monitoring system”.
It’s useful when you want to monitor network devices as a group, and you may have several of such groups, and you can’t or don’t want to use your router integration for this purpose. Sure, you can create manual automations, but then you can then do that for any blueprint.
Not all of the network devices are tracked by a router - some of these are remote devices outside your home network. And, yes, sure, additional pinging causes additional network traffic, but that’s rather minimal.
And, yes, this is meant as a quick-and-dirty solution to the network device tracking problem, which doesn’t require anything else.
The easiest way to achieve this would be to define a group comprising just a single entity. Alternatively, you could change the selector from the current group domain to a binary sensor with a suitable device class (probably “connectivity”).
When I go to blueprints and select server group - there is no group… What am I doing wrong here? I can see the group when browsing and it shows the history of the device just fine.
What do I need to do to make the group available to the blueprint?
