Node Red can get the user_id of the user that initiated the action from the mobile app:
msg.data.new_state.context.user_id
You can use that to monitor the entities/buttons and send a notification to only that one person. You can get the user_id for each user from Settings - People - Users.
[{"id":"a0cfced78d640e25","type":"tab","label":"Flow 3","disabled":false,"info":"","env":[]},{"id":"6946980ad325cd06","type":"server-state-changed","z":"a0cfced78d640e25","name":"Lamp1","server":"8be923df.d66f9","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"light.lamp_1_on_off","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":50,"y":80,"wires":[["1b0390a85ab950dc"]]},{"id":"3722cd2da7e82e43","type":"debug","z":"a0cfced78d640e25","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"data.new_state.context.user_id","targetType":"msg","statusVal":"","statusType":"auto","x":590,"y":100,"wires":[]},{"id":"1b0390a85ab950dc","type":"switch","z":"a0cfced78d640e25","name":"Direct each user_id","property":"data.new_state.context.user_id","propertyType":"msg","rules":[{"t":"eq","v":"28720e25df5f4660869fd3e2ef82ed8d","vt":"str"},{"t":"eq","v":"6f60846b24a5405d879e5300c1af9866","vt":"str"},{"t":"eq","v":"55e7aa394ff1490b92d2fb52d4a22959","vt":"str"},{"t":"eq","v":"f407c838ab394452824279908f84a50e","vt":"str"}],"checkall":"false","repair":false,"outputs":4,"x":270,"y":80,"wires":[["750e4f35ad64de3a","64c994e67ee65812"],["750e4f35ad64de3a","adc91ac46df6ab6f"],["750e4f35ad64de3a","f36f1aa4cf31d28f"],["750e4f35ad64de3a"]]},{"id":"750e4f35ad64de3a","type":"change","z":"a0cfced78d640e25","name":"Convert user_id to friendly name","rules":[{"t":"change","p":"data.new_state.context.user_id","pt":"msg","from":"38620e25df5f4660869fd3e2ab82ed8d","fromt":"str","to":"Sam","tot":"str"},{"t":"change","p":"data.new_state.context.user_id","pt":"msg","from":"6f84949b24a5405d879e5300c1af7400","fromt":"str","to":"Elliot","tot":"str"},{"t":"change","p":"data.new_state.context.user_id","pt":"msg","from":"41e7aa394ff1490b92d2fb52d4a302189","fromt":"str","to":"Robin","tot":"str"},{"t":"change","p":"data.new_state.context.user_id","pt":"msg","from":"f362c838ab394452824292000f84a50e","fromt":"str","to":"Supervisor","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":40,"wires":[["3722cd2da7e82e43"]]},{"id":"a6fb370a5fbf5605","type":"api-call-service","z":"a0cfced78d640e25","name":"Notify Sam","server":"8be923df.d66f9","version":5,"debugenabled":false,"domain":"notify","service":"mobile_app_sams_iphone","areaId":[],"deviceId":[],"entityId":[],"data":"{\"title\":\"Home Assistant Alert!\",\"message\":\"{{payload}}\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":590,"y":180,"wires":[[]]},{"id":"64c994e67ee65812","type":"function","z":"a0cfced78d640e25","name":"Set message text","func":"\nmsg.payload=\"Sam turned on Lamp 1. \";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":410,"y":180,"wires":[["a6fb370a5fbf5605"]]},{"id":"adc91ac46df6ab6f","type":"function","z":"a0cfced78d640e25","name":"Set message text","func":"\nmsg.payload=\"Elliot turned on Lamp 1. \";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":410,"y":220,"wires":[["c831140d9df45025"]]},{"id":"c831140d9df45025","type":"api-call-service","z":"a0cfced78d640e25","name":"Notify Elliot","server":"8be923df.d66f9","version":5,"debugenabled":false,"domain":"notify","service":"mobile_app_elliots_iphone","areaId":[],"deviceId":[],"entityId":[],"data":"{\"title\":\"Home Assistant Alert!\",\"message\":\"{{payload}}\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":590,"y":220,"wires":[[]]},{"id":"f36f1aa4cf31d28f","type":"function","z":"a0cfced78d640e25","name":"Set message text","func":"\nmsg.payload=\"Robin turned on Lamp 1. \";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":410,"y":260,"wires":[["a294bff88d3051c6"]]},{"id":"a294bff88d3051c6","type":"api-call-service","z":"a0cfced78d640e25","name":"Notify Robin","server":"8be923df.d66f9","version":5,"debugenabled":false,"domain":"notify","service":"mobile_app_robins_iphone","areaId":[],"deviceId":[],"entityId":[],"data":"{\"title\":\"Home Assistant Alert!\",\"message\":\"{{payload}}\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":590,"y":260,"wires":[[]]},{"id":"577f5d59033edeb7","type":"comment","z":"a0cfced78d640e25","name":"Monitor Lamp 1","info":"","x":80,"y":40,"wires":[]},{"id":"8be923df.d66f9","type":"server","name":"homeassistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":""}]
