when Hass die, I can see in AppDaemon log:
WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
I would like to send Mqqt message when this occur and do certain things.
Just listen for the plugin_stopped
event.
import appdaemon.plugins.hass.hassapi as hass
class MonitorPlugin(hass.Hass):
def initialize(self):
self.listen_event(self.plugin_event, "plugin_stopped") # or "plugin_started" when Home Assistant starts.
def plugin_event(self, event_name, data, kwargs):
self.log(event_name)
self.log(data)
self.log(kwargs)
# Do whatever you need here.
data
will contain a dictionary with the name of the plugin that caused the event, e.g. {‘name’: ‘HASS’}
Also is possible to create Input_boolean
and try to toggle it every X seconds. If Hass is not responding, warning is raised and boolean will remain a same. This works even when Appdaemon freshly starts or reload apps after editing and Hass is off.
configuration.yaml
input_boolean:
hass_respond:
name: "Hass is responding"
initial: off
icon: mdi:car
Your APP
self.run_every(self.send_state, datetime.datetime.now() + datetime.timedelta(seconds=1), 'every X seconds')
def send_state(self, kwargs):
last_state = self.get_state("input_boolean.hass_respond", default="off")
self.log(last_state)
self.toggle("input_boolean.hass_respond")
time.sleep(1)
self.log(state)
if last_state != state:
self._state = True
self.log("running")
else:
self._state = False
self.log("stopped")
#Do what You need
