Send photo via Notifications for Android TV/FireTV
I’m wondering how to send photo via Notifications for Android TV/FireTV?
That’s not possible. The app only supports displaying text + icon. The icon in theory could be some other picture, but when I implemented dynamic icons the core devs voted against my implementation, so I have stripped out again.
Thanks @danielperna84 for your reply.
However I believe the latest version can support photo (not just icon). Please see these…
This is great for showing snapshot from cameras when intruder is detected.
Huh, thanks for pointing that out. I didn’t follow the release notes, so I was unaware of that. I’ll have a look at it. :slight_smile:
No problem. I have moved this to feature request category. Hope this will be supported soon. Thanks.
I’m sorry. I’m wondering is anyone working on this?
Also see Notifications for AndroidTV - #2 by danielperna84 for additional information.
I have to apologize. Even though I said I’ll have a look at it, I didn’t manage to do so for a lack of time. I’d be happy to see if someone else could contribute.
No need to apologize. I wish I could contribute but it is too complicated for me.
@masterkenobi can you post your config for sending a camera image, everything I try seems to be invalid. Thanks
This is example action in my automation…
    - service: notify.alltvs
      data_template:
        title: "Alert"
        message: "Someone is at the car porch."
          file:
            url: http://[snapshot URL]
            username: !secret cam1_username
            password: !secret cam1_password
Hi @masterkenobi ,
OId thread, but I was just wondering is this still works?
Did you just put this into your configurations.yaml file:
notify:
  - platform: nfandroidtv
    name: Nvidia Shield TV
    host: xxx.xxx.xxx.xxx
and then added the above configuration of yours? Then you will get the Notification on your Android TV with a nice picture as well?
Hi
Got this working and its great but how do you get the Home Assistant Logo or something next to the message and Title ?
I can get URL images but not local also, do you have to whitelist the path or anything ?
Martyn
Maybe something like PiPup would help some people that want something a little more flexible as it’s just a simple post with Json data that can be done with HA, nodered, iOS shortcuts, tasker etc etc.
Hi
Thanks for that. I can do that all in this app. ie image above text. I just wanted to see if I could put the HA logo next to the text on the left.
Thanks anyway.
Martyn
Here is an example of how to send a notification in Node Red, as I couldn’t really find any examples on the net, and had to muddle my way through it.
This is using a Sony TV, and yes, PiPup is great. It doesn’t have any ads like the “Notifications for Android TV” does, and it was really easy to set up.
[{"id":"87101dd.987786","type":"tab","label":"Delivery notification on TV","disabled":false,"info":""},{"id":"ab70ac50.fd88e8","type":"http request","z":"87101dd.987786","name":"","method":"POST","ret":"txt","paytoqs":"body","url":"http://InsertYourTV_IP:7979/notify","tls":"","persist":false,"proxy":"","authType":"","x":910,"y":260,"wires":[["f0f8665.b184b18"]]},{"id":"92614fa6.0c8818","type":"template","z":"87101dd.987786","name":"page","field":"payload","fieldType":"msg","format":"json","syntax":"mustache","template":"{\n  \"duration\": 30,\n  \"position\": 4,\n  \"title\": \"Delivery has arrived!\",\n  \"titleColor\": \"#0066cc\",\n  \"titleSize\": 70,\n  \"message\": \"Go answer the door!\",\n  \"messageColor\": \"#000000\",\n  \"messageSize\": 64,\n   \"media\": { \"image\": {\n    \"uri\": \"https://i.imgur.com/21hPmO3.jpg\", \"width\": 576\n  }}\n}","x":770,"y":260,"wires":[["ab70ac50.fd88e8"]]},{"id":"f0f8665.b184b18","type":"debug","z":"87101dd.987786","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1090,"y":260,"wires":[]},{"id":"4c0dd616.866118","type":"mqtt in","z":"87101dd.987786","name":"","topic":"Home/Office/External/DeliveryMotion","qos":"0","datatype":"auto","broker":"","x":360,"y":260,"wires":[["661d0696.ab0da8"]]},{"id":"eca37438.18c338","type":"comment","z":"87101dd.987786","name":"Delivery has arrived","info":"","x":315,"y":226,"wires":[]},{"id":"661d0696.ab0da8","type":"switch","z":"87101dd.987786","name":"on / off","property":"payload","propertyType":"msg","rules":[{"t":"regex","v":"on","vt":"str","case":true},{"t":"regex","v":"off","vt":"str","case":true}],"checkall":"true","repair":false,"outputs":2,"x":620,"y":260,"wires":[["92614fa6.0c8818"],[]]}]
Just having a play with your node red. Ive changed the IP of my android Sony Tv but its not going through.
I get the error below ECONNRefused
Thanks Martyn
Did you follow the instructions here: https://github.com/rogro82/PiPup?
