Send pictures attachments from Motioneye outside www folder to telegram
Dear all,
I have HA and MotionEye integration in a RP PI 4. I can send pictures attachments to telegram when the file is in the www directory (/config/www). But MotionEye don’t allow to save the pictures in other file than …/share/motioneye/CameraX.
I tried to fix this whith all the following options:
1.- Modify the storage folder in motioneye integration, for example I put in the file storage section “/config/www/motioneye/Camera1” or “/local/motioneye/Camera1” and others to try. Then I restart, and dont works. Motioneye dont save the picures in this new folder.
2.- Modify configuration.yaml to add the following options:
2.1.-
whitelist_external_dirs:
- '/share/motioneye/Camera1'
2.2.-
allowlist_external_dirs:
  - /share/motioneye/Camera1
allowlist_external_urls:
  - https://xxxxxx.duckdns.org:8123/share/motioneye/Camera1/jose.jpg
I am very desperate with this problem, testing and cheking for houres, and imposible to find a solution.
The only solution for send pictures is when these pictures are in the ww folder, then all works fine. In my case I cand send notifications to telegram with this format:
Automations:
- id: 4b4b073ca86b42519bc2f542e823d211
  alias: Envio telegram cuando se detecta movimiento
  - platform: webhook
    webhook_id: '123321'
  - data:
        photo:
          caption: PruebaFoto
          url: https://xxxxxxxxxx.duckdns.org:8123/local/jose.jpg
      message: holahola
      title: Home Assistant
    service: notify.telegram
Node red:
Where the function node:
msg.payload = {"caption": "PruebaFoto", "url": "https://josemsubcnas.duckdns.org:8123/local/jose.jpg"}
return msg;
and the Send Phot Node is:
Please any help about this?. Thanks in advance…
Jose
Any Help about this please? Thanks
Please can someone help me?
I have the same question :slight_smile:. Can’t figure it out at this moment…
