I have HA installed on my rPi and currently presence detection (over network scan) and weather conditions are presented fine on the UI.
Furthermore I have an old setup with 433mHz switches being controlled by remote controls and a bridge (Trust ICS-1000) (also known as KAKU) which I would like to integrate within my HA setup.
I found out that I can control my Trust bridge over my internal network based on UDP broadcasts on port 9760. These contain the following fields:
< id > < room > < device > < function > | text1 | text2 |
I would like to set up a connection between my rPi (with HA installed) and the Trust bridge. I would then like to send UDP packages from my rPi to the bridge, to control my 433mHz switches.
I know I’d probably be better off with an 433mHz transceiver like an RFXcom, but I consider it as a challenge to use the bridge as that transceiver.
but it works only once . . . for send again the packege i need to restart hassio . . . have you some advise for me ?
Very appreciate any suggest
Bye
Paolo
