Send variable to HA via http post api
I am using Tasker on Android to trigger an automation with automation.trigger in an HTTP Post API call which works fine. But is there any option to submit a variable via http post to homeassistant in the automation?
Maybe something like:
"entity_id": "automation.check_weather"
"custom_variable":"InputMyOwnVariableHere"
I would suggest using a script instead of an automation. Then you can invoke the script via the REST API, including passing data. See Calling a service, and Passing variables to scripts.
