I made a wake_on_lan switch to wake and sleep my PC years ago and worked pretty well for a long time, but changed a few hardware in the past few months and now is the time to make it work again.
The problem is when I run this command from terminal, it works well, but as soon I turn the switch on the UI with this command I get return code: 255; NoneType: None
I’m still trying to figure it alll out… it’s peripherally part of what bit AD and HAs addons so hard yesterday.
So in essence in an addon (and here I assume terminal/SSH) now gets the config folder mounted as /homeassistant so it can read anything in it. (but of course you have to refer to it as /homeassistant/* and thferes some other magic too. I haven’t unwound yet.)
I think what’s going on is when in context of core /homeassistant is /config so…
if op changes the automation to use /config/* instead of /homeassistant/*?
