Sending data from rgb light control box depending time automation script via mqtt
Hi.
I have aquarium with rgb leds, which are connected on ESP8266.
I need to sending every hour information about rgb color and brightness over MQTT.
This is no problem, but I was created light control box for every hour (24 control box). Now I need read settings from correct control box and send over mqtt payload
> lights.yaml
>    - platform: mqtt
>     name: 'Aquarium light 0'
>     state_topic: 'aquarium/rgb1/light/status'
>     command_topic: 'aquarium/rgb1/light/switch'
>     brightness_state_topic: 'aquarium/rgb1/brightness/status'
>     brightness_command_topic: 'aquarium/rgb1/brightness/set'
>     rgb_state_topic: 'aquarium/rgb1/rgb/status'
>     rgb_command_topic: 'aquarium/rgb1/rgb/set'
>     brightness_scale: 100
>     optimistic: true
automations.yaml
- alias: set_rgb_light
    platform: time
    at: '10:00:00'
   - service: mqtt.publish
     data_template:
      topic: 'aquarum/rgb1/brightness/set'
      payload: '{{ states.light.aquarium_light_0.brightness.state | int }}'   <- not work
     data_template:
      topic: 'aquarum/rgb1/rgb/set'
      payload: '222,125,154'   <- work,
