I had flashed a genereic IR blaster with a BK7231N chip. Receiving IR codes was easy. Just go to webapp and the log tab, press button on the IR remote and a code like "IR_NEC2 0x6DD2 0x2 1 " would appear. This was easy to use in Mqtt automations.
It was mujch more difficult to find out how to send IR codes. I had to convert the code.
From the logs command line you could convert the received code from;
IR_NEC2 0x6DD2 0x2 1 to NEC2 6DD2-2-1
You could then send that code form the command line of the device in the webapp.
To send from http “http://192.168.0.111/cm?cmnd=IRSend NEC2 6DD2-2-1”
To use it in an automation with mqtt;
- action: mqtt.publish
metadata: {}
qos: 0
retain: false
topic: cmnd/obk1irBlaster/IRSend
payload: NEC 6DD2-2-1
