I’m configuring a Loxone System to raise volume from a physical button to a Chromecast. Thanks to HAOS I have a nice HTTP REST interface I can easily use.
However, the basic media player “volume up” command raises the volume by 10%, and I don’t want it. I want it to go up in steps.
So I did manage to create a script that does that:
However, I don’t want to create too many scripts and then call them, as I have several Chromecasts at home. I’d like to send the content of “data” as part of the HTTP command, so that I can easily communicate with multiple devices without the use of scripts.
Is that possible?
I tried to send an HTTP Request with a payload like this:
volume:
alias: Increase volume
mode: parallel
descrption: >
increase the volume of any media player.
fields:
player:
description: The media player(s)
required: True
selector:
entity:
mulitple: True
domain: media_player
direction:
description: Volume Up or Volume Down
required: True
selector:
select:
options:
- label: Volume Up
value: up
- label: Volume Down
value: down
level:
description: Increment
default: 0.1
selector:
number:
min: 0.0
max: 0.0
step: 0.01
variables:
media_player: "{{ player if player is list else [player] }}"
current: "{{ media_player | map('state_attr', 'volume_level') | select('is_number') | list | average }}"
step: "{{ level | default(0.1) }}"
volume_level: "{{ current + step if direction == 'up' else current - step }}"
sequence:
- action: media_player.volume_set
entity_id: "{{ media_player }}"
volume_level: "{{ volume_level }}"
mode: parallel
descrption: >
fields:
player:
required: True
selector:
entity:
mulitple: True
direction:
required: True
selector:
select:
options:
- label: Volume Up
value: up
value: down
level:
default: 0.1
selector:
number:
min: 0.0
max: 0.0
step: 0.01
variables:
sequence:
It worked! I just contained two typos (description and multiple). Here is the version without typos for future reference.
Thank you petro!
mode: parallel
description: |
fields:
player:
required: true
selector:
entity:
multiple: true
direction:
required: true
selector:
select:
options:
- label: Volume Up
value: up
value: down
level:
default: 0.1
selector:
number:
min: 0
max: 0
step: 0.01
variables:
current: >-
list | average }}
sequence:
