Sending MQTT data from my scale (Arduino) to HA, database receive/present some totally wrong data
Hi
I have a bee hive scale that sends data to my Home assistant database, interval of 10 sec.
I have logged all data on sender side
Load on scale is 25,30 Kg
Values sent, like 16000 has almost 100% correct values, biggest is 25,36 kg, smallest is 25,28 kg. Only grams, negligible in the bigger picture, I will also not show grams, i will only need one decimal, 25.3 kg
My home assistant present this:
As you se values of 4.000.000 kg makes the graph non informative.
So my question to you, how can this be fixed when sender system is sending correct data?
Thanks up front!
P
