Sending several volume up commands in one call to remote.send_command
I have one of the Cube controllers
I can get the number of times I want the volume to be raised using
{{(trigger.event.data.args.relative_degrees *-1 / 360 * 45) | int()}}
I have it working using a repeat at the yaml level but this is a bit slow
Ideally what I want is to use a template to add the number of lines of
VolumeUp or VolumeDown that I want.
Would repeat the number of times computerd above so a value of 3 would return
command:
  - VolumeUp
  - VolumeUp
  - VolumeUp
device: 60329136
what do you mean , slow? I use codes sending to remotes/media player entities , and it works fine. Maybe it’s your receiver.
It’s probably the Harmony, which is why I want to invoke the remote call once and then send several codes at once.
I have ended up with
command: >
  {% set r = (trigger.event.data.args.relative_degrees / 360 * 45) %}
  {% set i =  r|int() %}
  {% set x = ['VolumeUp']|batch(i, 'VolumeUp')%}
  {%- for row in x %}
    {{ row }}
  {%- endfor  %}
Which works much quicker. Is there a simpler way?
