Sending state of wall switch to Hass using rpi_rf?
I have set up a solution with a sender/receiver for my 433Mhz power switches using rpi_rf.
See video on youTube..
Switching on/off from Hass works perfect.
The problem is, if I use a wall switch to turn the power switch on and off, the event is not recognized by Hass.
How can I integrate the wall switch as trigger into Hass?
Best regards,
Christian
Have you found any solution to reflect the state?
My solution was to hook sonoffs to the same fixture so that when you turn the light on it powers the sonoff and you can use the WiFi signal from the sonoff with a template switch.
Idea came from this video
