Just now, I have changed the [http] setting for major mopidi instance from the
hostname = 192.168.1.246 to hostname= :: and after that my speakers started to produce ‘squiky’ sounds as if it is streaming from the cache… For Mopidy I have a chunk of messages from the last reboot as below:
лют 14 18:20:45 tigraresidence-NUC10i7-srv1 systemd[1]: Started Mopidy music server.
лют 14 18:20:45 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MainThread] mopidy.__main__ Starting Mopidy 3.1.1
лют 14 18:20:45 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MainThread] mopidy.config Loading config from builtin defaults
лют 14 18:20:45 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MainThread] mopidy.config Loading config from file:///usr/share/mopidy/conf.d/mopidy.conf
лют 14 18:20:45 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MainThread] mopidy.config Loading config from file:///etc/mopidy/mopidy.conf
лют 14 18:20:45 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MainThread] mopidy.config Loading config from command line options
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MainThread] mopidy.__main__ Enabled extensions: bookmarks, m3u, mpd, mobile, http, stream, file, mpris, youtube, autoplay, internetarchive, iris, muse, mowecl, musicb>
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MainThread] mopidy.__main__ Disabled extensions: scrobbler, radionet, local
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [MainThread] mopidy.__main__ Found local configuration errors. The extension has been automatically disabled:
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [MainThread] mopidy.__main__ local/media_dir must be set.
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [MainThread] mopidy.__main__ Found radionet configuration errors. The extension has been automatically disabled:
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [MainThread] mopidy.__main__ radionet/favorite_stations must be set.
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [MainThread] mopidy.__main__ Found scrobbler configuration errors. The extension has been automatically disabled:
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [MainThread] mopidy.__main__ scrobbler/username must be set.
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [MainThread] mopidy.__main__ scrobbler/password must be set.
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [MainThread] mopidy.__main__ Please fix the extension configuration errors or disable the extensions to silence these messages.
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MainThread] mopidy_mowecl VERSION 0.4.0
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MainThread] mopidy_autoplay Mopidy-Autoplay 0.2.1
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MainThread] mopidy.commands Starting Mopidy mixer: SoftwareMixer
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MainThread] mopidy.commands Starting Mopidy audio
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MainThread] mopidy.commands Starting Mopidy backends: YouTubeBackend, InternetArchiveBackend, BookmarksBackend, FileBackend, M3UBackend, StreamBackend
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [YouTubeBackend-3] mopidy_youtube using bs4API
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MainThread] mopidy.commands Starting Mopidy core
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [Audio-2] mopidy.audio.actor Audio output set to "audioresample ! audioconvert ! wavenc ! filesink location=/tmp/snapfifo"
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MainThread] mopidy.commands Starting Mopidy frontends: YouTubeAutoplayer, MprisFrontend, IrisFrontend, InputFrontend, MopidyCoreListener, AutoplayFrontend, HttpFronte>
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [IrisFrontend-12] mopidy_iris.core Starting Iris 3.55.4
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [MprisFrontend-11] mopidy_mpris.frontend MPRIS frontend setup failed (g-io-error-quark: Cannot autolaunch D-Bus without X11 $DISPLAY (0))
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: ERROR [Core-9] mopidy.core.playlists BookmarksBackend backend caused an exception.
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: Traceback (most recent call last):
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: File "/usr/lib/python3/dist-packages/mopidy/core/playlists.py", line 16, in _backend_error_handling
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: yield
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: File "/usr/lib/python3/dist-packages/mopidy/core/playlists.py", line 68, in as_list
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: playlists = future.get()
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: File "/usr/lib/python3/dist-packages/pykka/_threading.py", line 45, in get
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: _compat.reraise(*self._data['exc_info'])
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: File "/usr/lib/python3/dist-packages/pykka/_compat/__init__.py", line 29, in reraise
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: raise value
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: File "/usr/lib/python3/dist-packages/pykka/_actor.py", line 193, in _actor_loop
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: response = self._handle_receive(envelope.message)
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: File "/usr/lib/python3/dist-packages/pykka/_actor.py", line 299, in _handle_receive
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: return callee(*message.args, **message.kwargs)
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: File "/usr/local/lib/python3.8/dist-packages/mopidy_bookmarks/backend.py", line 41, in as_list
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: bookmark_names = self.bmcontroller.as_list().get()
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: File "/usr/local/lib/python3.8/dist-packages/mopidy_bookmarks/backend.py", line 28, in bmcontroller
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: self._bmcontroller = pykka.ActorRegistry.get_by_class_name(
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: IndexError: list index out of range
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [HttpFrontend-22] mopidy.http.actor HTTP server running at [::]:6680
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MainThread] mopidy_mpd.actor MPD server running at [::]:6600
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: ERROR [InputFrontend-13] pykka Unhandled exception in InputFrontend (urn:uuid:8d601026-077f-4fdf-b6c6-14ed984acccb):
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: File "/usr/local/lib/python3.8/dist-packages/evdev/device.py", line 126, in __init__
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: fd = os.open(dev, os.O_RDWR | os.O_NONBLOCK)
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: FileNotFoundError: [Errno 2] No such file or directory: ';needs to be set'
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: During handling of the above exception, another exception occurred:
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: File "/usr/lib/python3/dist-packages/pykka/_actor.py", line 186, in _actor_loop
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: self.on_start()
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: File "/usr/local/lib/python3.8/dist-packages/mopidy_headless/frontend.py", line 112, in on_start
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: self.inputthread.register_handlers([
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: File "/usr/local/lib/python3.8/dist-packages/mopidy_headless/input.py", line 56, in register_handlers
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: self.register_handler(handler)
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: File "/usr/local/lib/python3.8/dist-packages/mopidy_headless/input.py", line 32, in register_handler
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: device = InputDevice(handler.device_fn)
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: File "/usr/local/lib/python3.8/dist-packages/evdev/device.py", line 128, in __init__
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: fd = os.open(dev, os.O_RDONLY | os.O_NONBLOCK)
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MainThread] mopidy.commands Starting GLib mainloop
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [StreamBackend-8] mopidy.internal.http Download of 'http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_translate.mp3' faile>
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [StreamBackend-8] mopidy.stream.actor Unwrapping stream from URI (http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_transl>
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [StreamBackend-8] mopidy.stream.actor Problem looking up http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_translate.mp3
лют 14 18:20:46 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [Core-9] mopidy.core.tracklist Track is not playable: http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_translate.mp3
лют 14 18:20:52 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MpdSession-37] mopidy_mpd.session New MPD connection from [::ffff:192.168.1.3]:49246
лют 14 18:26:29 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [StreamBackend-8] mopidy.internal.http Download of 'http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_translate.mp3' faile>
лют 14 18:26:29 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [StreamBackend-8] mopidy.stream.actor Unwrapping stream from URI (http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_transl>
лют 14 18:26:29 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [Core-9] mopidy.core.tracklist Track is not playable: http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_translate.mp3
лют 14 18:26:30 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [StreamBackend-8] mopidy.internal.http Download of 'http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_translate.mp3' faile>
лют 14 18:26:30 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [StreamBackend-8] mopidy.stream.actor Unwrapping stream from URI (http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_transl>
лют 14 18:26:30 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [Core-9] mopidy.core.tracklist Track is not playable: http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_translate.mp3
лют 14 18:26:31 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [StreamBackend-8] mopidy.internal.http Download of 'http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_translate.mp3' faile>
лют 14 18:26:31 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [StreamBackend-8] mopidy.stream.actor Unwrapping stream from URI (http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_transl>
лют 14 18:26:31 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [Core-9] mopidy.core.tracklist Track is not playable: http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_translate.mp3
лют 14 18:26:45 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [StreamBackend-8] mopidy.internal.http Download of 'http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_translate.mp3' faile>
лют 14 18:26:45 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [StreamBackend-8] mopidy.stream.actor Unwrapping stream from URI (http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_transl>
лют 14 18:26:45 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [Core-9] mopidy.core.tracklist Track is not playable: http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_translate.mp3
лют 14 18:27:42 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [StreamBackend-8] mopidy.internal.http Download of 'http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_translate.mp3' faile>
лют 14 18:27:42 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [StreamBackend-8] mopidy.stream.actor Unwrapping stream from URI (http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_transl>
лют 14 18:27:42 tigraresidence-NUC10i7-srv1 mopidy[143870]: WARNING [Core-9] mopidy.core.tracklist Track is not playable: http://192.168.1.3%253A8123/api/tts_proxy/23644687d21b6329320f515ecad6b7162c771aab_ru_-_google_translate.mp3
лют 14 18:32:20 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MpdSession-1415] mopidy_mpd.session New MPD connection from [::ffff:192.168.1.239]:42712
лют 14 18:32:20 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MpdSession-1417] mopidy_mpd.session New MPD connection from [::ffff:192.168.1.239]:42714
лют 14 18:32:34 tigraresidence-NUC10i7-srv1 mopidy[143870]: INFO [MpdSession-1445] mopidy_mpd.session New MPD connection from [::ffff:192.168.1.239]:42716
yes, I do se the file snapfifo in the tmp dir.
And this is the log for the Snapserver
root@tigraresidence-NUC10i7-srv1:/tmp# tail -f /var/log/syslog |grep -e snap
Feb 14 18:46:40 tigraresidence-NUC10i7-srv1 snapserver[125872]: Error reading message header of length 0: End of file
Feb 14 18:46:40 tigraresidence-NUC10i7-srv1 snapserver[125872]: onDisconnect: 8f759bec-e70f-4ba5-aaaa-b35ceb2fb71b
Feb 14 18:46:41 tigraresidence-NUC10i7-srv1 snapserver[125872]: StreamServer::NewConnection: 192.168.1.239
Feb 14 18:46:41 tigraresidence-NUC10i7-srv1 snapserver[125872]: Hello from 8f759bec-e70f-4ba5-aaaa-b35ceb2fb71b, host: SM-G975F, v0.23.0, ClientName: Snapclient, OS: Android 11, Arch: arm64-v8a, Protocol version: 2
Feb 14 18:46:52 tigraresidence-NUC10i7-srv1 snapserver[125872]: Error reading message header of length 0: End of file
Feb 14 18:46:52 tigraresidence-NUC10i7-srv1 snapserver[125872]: onDisconnect: 8f759bec-e70f-4ba5-aaaa-b35ceb2fb71b
Feb 14 18:46:52 tigraresidence-NUC10i7-srv1 snapserver[125872]: Error in socket shutdown: Transport endpoint is not connected
Feb 14 18:46:52 tigraresidence-NUC10i7-srv1 snapserver[125872]: StreamServer::NewConnection: 192.168.1.239
Feb 14 18:46:52 tigraresidence-NUC10i7-srv1 snapserver[125872]: Hello from 8f759bec-e70f-4ba5-aaaa-b35ceb2fb71b, host: SM-G975F, v0.23.0, ClientName: Snapclient, OS: Android 11, Arch: arm64-v8a, Protocol version: 2
And RPi snap client keeps logging me this continiously:
root@raspberrypi:~# tail -f /var/log/syslog |grep -e snap
Feb 14 16:50:12 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -100491
Feb 14 16:50:13 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -100192
Feb 14 16:50:15 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -100516
Feb 14 16:50:16 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -100442
Feb 14 16:50:17 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -100371
Feb 14 16:50:18 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -100439
Feb 14 16:50:19 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -100167
Feb 14 16:50:21 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -100033
Feb 14 16:50:22 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -100148
Feb 14 16:50:23 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -100348
Feb 14 16:50:24 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -100426
Feb 14 16:50:25 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -100499
Feb 14 16:50:27 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101087
Feb 14 16:50:29 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -100782
Feb 14 16:50:30 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101238
Feb 14 16:50:31 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101069
Feb 14 16:50:32 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101159
Feb 14 16:50:33 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -100749
Feb 14 16:50:35 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101233
Feb 14 16:50:36 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -100489
Feb 14 16:50:37 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101144
Feb 14 16:50:38 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101173
Feb 14 16:50:39 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101337
Feb 14 16:50:41 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101364
Feb 14 16:50:42 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101484
Feb 14 16:50:43 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101799
Feb 14 16:50:44 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101268
Feb 14 16:50:45 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101762
Feb 14 16:50:47 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101578
Feb 14 16:50:48 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101827
Feb 14 16:50:49 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101174
Feb 14 16:50:50 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101408
Feb 14 16:50:51 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101347
Feb 14 16:50:53 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101555
Feb 14 16:50:54 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101590
Feb 14 16:50:55 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101533
Feb 14 16:50:56 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -101876
Feb 14 16:50:58 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -99743
Feb 14 16:50:59 raspberrypi snapclient[581]: pMiniBuffer->full() && (abs(pMiniBuffer->mean()) > 50): -99532
Thanks!
