Sending value to number helper not working
Im having trouble getting an automation to set the value of a number helper. Here is what it looks like. What i want to do here is send the battery level value to the number helper everytime there is a change.
alias: EV SOC
description: “”
  • platform: state
    entity_id:
    • sensor.ioniq_ev_battery_level
      condition:
  • service: input_number.set_value
    entity_id: input_number.soc
    value: sensor.ioniq_ev_battery_level
    mode: single
Please follow the community guideline and properly format your code.
As shown, your automation is trying to set the string “sensor.ioniq_ev_battery_level” to an input number which is not valid. If you want to set the value of the sensor’s state to the input number, you need to use a template:
  - service: input_number.set_value
      value: "{{ states('sensor.ioniq_ev_battery_level') }}"
Thank you very much, that did the trick! Im a real noob with this kind of stuff and ive spent nearly 6h trying different things…
What are you trying to achieve by mirroring the sensor to an input number?
