Sends Value from HA to IHC Controller
Send actual value from a sensor to the IHC controller, you can find the IHC id nr. by starting your IHC Visual Software find the input or function block you want to send the value to, press Ctrl and do a mouse over, then you see the ID.
ID
blueprint:
  name: Float value to IHC
  description: Tranfer a value from HA to IHC.
  domain: automation
  source_url: https://gist.github.com/SKLundgren/ffc732f9e75df084db7713b4ff49833f#file-float_to_ihc-yaml
  input:
      selector:
        entity:
          domain: sensor
    ihc_id:
      description: The unique IHC ID nr.
      default: 0
      selector:
        number:
          min: 0
          max: 10000000000
  - platform: state
    entity_id: !input sensor
  - service: ihc.set_runtime_value_float
      ihc_id: !input ihc_id
      value: '{{trigger.to_state.state}}'
mode: single
In current windows version its impossible to see this id. … id disapears before you catch it
Brug denne her, Preben.
https://www.dingus.dk/updated-ihc-alternative-service-view/
can some one help me with getting the target temperature from generic thermostat sent to IHC?, I can only get a fixed value sent.
I solved it with the following
alias: TEST IHC 2
description: “”
  • platform: state
    entity_id:
    • climate.study
      attribute: temperature
      condition:
  • service: ihc.set_runtime_value_float
    controller_id: 0
    value: “{{ float(state_attr(‘climate.study’,‘temperature’))}}”
    ihc_id: 18573844
    mode: single
    max: 10
Hej Jesper
I am really strugling with this.
Can i ask you to make a minguide for this.
what is this output ? ihc_id: 18573844
I guess you created some kind of sensor right ?
Regards ’
Bozidar
that is the “sensor input” in the IHC controller.
when i change the temperature setpoint in HA the value is then sent over to the IHC controller which controls an output for the heat.
Tak Jesper .
