Sendspin time message timeouts and bad stuttering / no audio
A few weeks ago I built a Sendspin player based on this design: [GitHub - RealDeco/SendspinZero: Sendspin Audio Receiver for your Stereo/Amplifier · GitHub] and was very happy with it - it just worked. Very well!
Yesterday, while playing, it started stuttering with big breaks in the audio. Some fault finding led me to look at the ESPHome logs, which contained entries like this:
INFO ESPHome 2026.4.3 INFO Reading configuration /config/esphome/sendspin-lounge.yaml... INFO Starting log output from 192.168.x.x using esphome API INFO Successfully resolved sendspin-lounge @ 192.168.x.x in 0.000s INFO Successfully connected to sendspin-lounge @ 192.168.0.42 in 0.651s INFO Successful handshake with sendspin-lounge @ 192.168.0.42 in 0.668s [08:32:05.264][W][sendspin.time_burst:044]: Time message 1/8 timed out [08:32:06.299][W][sendspin.time_burst:044]: Time message 2/8 timed out [08:32:07.259][W][sendspin.time_burst:044]: Time message 3/8 timed out [08:32:08.342][W][sendspin.time_burst:044]: Time message 4/8 timed out [08:32:09.328][W][sendspin.time_burst:044]: Time message 5/8 timed out [08:32:10.353][W][sendspin.time_burst:044]: Time message 6/8 timed out [08:32:10.811][W][sendspin.protocol:086][httpd]: Mismatched time message history, discarding measurement [08:32:10.811] [W][sendspin.protocol:086][httpd]: Mismatched time message history, discarding measurement [08:32:11.512] [W][sendspin.time_burst:044]: Time message 7/8 timed out [08:32:12.349] [W][sendspin.time_burst:044]: Time message 8/8 timed out [08:32:12.389] [W][sendspin.protocol:086][httpd]: Mismatched time message history, discarding measurement [08:32:12.389] [W][sendspin.protocol:086][httpd]: Mismatched time message history, discarding measurement [08:32:14.549] [W][sendspin.protocol:086][httpd]: Mismatched time message history, discarding measurement [08:32:15.223] [W][sendspin.protocol:086][httpd]: Mismatched time message history, discarding measurement [08:32:16.712] [W][sendspin.protocol:086][httpd]: Mismatched time message history, discarding measurement
That was with Music Assistant 2.8.6 and I have since downgraded to 2.8.5 (which worked well) but the problem persisted so I upgraded to 2.8.6 again.
I have also rebuilt the ESPHome device, including clean build but, again, that didn’t help.
This is on HAOS running on a desktop PC:
  • Core 2026.4.4
  • Supervisor 2026.04.0
  • Operating System 17.2
  • Frontend 20260325.8
Does anyone have any ideas what could be causing this, diagnostic actions and, ideally, corrective actions please?
First thing to understand is this is still in beta and changing a lot.
That being said if you are using @RealDeco code it should be working. What version of esphome are you using?
If you have modified the code at all post it here. Also the code was changed 2 weeks ago so you may want to check the external components in the code.
Thanks, @Arh - I understand that it is beta but what threw me was that it developed the problem suddenly, while playing, after working unchanged for a few weeks.
This (Sendspin) is a really exciting development and the work of @RealDeco is brilliant so please don’t interpret any of this as criticism.
The actual yaml follows - I have added a few sections but all these were after the problems started and made no difference. I also changed the LED brightness but, again, after the problem started.
I’m now on ESPHome 2026.4.3 - when this started I was on 2026.4.1 and went direct to 2026.4.3 in an attempt to address the issue.
I’m using the Toslink version.
# See https://github.com/RealDeco/SendspinZero/tree/main
## SendspinZero for Analog + Digital Coax and Toslink versions WITHOUT display. Edit the settings below.
substitutions:
  friendly_name: "Sendspin: Lounge"
## SETTINGS ######################################################################################################################################
  # Startup sound, options are: Home_Connected or Home_Connected_Male
  startup_sound_file: Home_Connected
  # your home assistant weather entity, in most cases the same.
  ha_weather_entity: weather.forecast_home
packages: # uncomment the one you use (analog for normal jack, digital for coax or toslink spdif)
#  hw: #ANALOG
#    url: https://github.com/RealDeco/SendspinZero.git
#    ref: main
#    refresh: 0s
#    files:
#      - analog_speaker_config.yaml
  hw: #DIGITAL
    ref: main
    refresh: 0s
    files:
      - digital_speaker_config.yaml
esphome:
  friendly_name: ${friendly_name}
  min_version: 2026.1.0
  name_add_mac_suffix: false
  on_boot:
    priority: -100
    then:
      - script.execute: led_red
esp32:
  variant: esp32s3
  framework:
    type: esp-idf
logger:
  level: warn
api:
  on_client_connected:
    - lambda: |-
        if (!id(boot_sound_played)) {
          id(boot_sound_played) = true;
          if (id(startup_sound_switch).state) {
            id(play_sound)->execute(true, std::string("ready_sound"));
ota:
  - platform: esphome
wifi:
  ssid: !secret wifi_ssid
  ap:
psram:
  mode: quad
  speed: 80MHz
captive_portal:
external_components:
  - source:
      # https://github.com/esphome/esphome/pull/14933
      type: git
      url: https://github.com/kahrendt/esphome
      ref: 890e33f99af2c2ea15dc74c3ec4cf32d25203526
    components: [const, media_source, sendspin, generic_image]
  - source:
      # https://github.com/esphome/esphome/pull/12429
      type: git
      url: https://github.com/esphome/esphome
      ref: ff8ce89556748509d7ee8724e12d9d43d3c8c1e8
    refresh: 0s
    components: [http_request]
# I tried adding this - it made no difference.
#network:
#  enable_high_performance: false
# I added the next two after the problems started
text_sensor:
  - platform: wifi_info
    ip_address:
      name: "${friendly_name} IP Address"
      icon: mdi:ip-network
  - platform: wifi_signal
    name: "${friendly_name} WiFi Signal"
    update_interval: 60s
sendspin:
  task_stack_in_psram: false
http_request:
  buffer_size_rx: 2048  # Reduces CPU load when streaming audio
audio_file:
  - id: ready_sound
    file: https://github.com/RealDeco/xiaozhi-esphome/raw/main/sounds/${startup_sound_file}.flac
media_source:
  - platform: audio_file
  - platform: http_request
    buffer_size: 250000
    buffer_size: 500000
  - platform: sendspin
media_player:
    name: Sendspin Group Media Player
  - platform: speaker_source
    announcement_pipeline:
      format: FLAC
      num_channels: 1
      sample_rate: ${media_sample_rate}
      speaker: announcement_resampling_speaker
      sources:
        - audio_file_announcement_source
        - http_announcement_source
    media_pipeline:
      format: FLAC
      num_channels: 2
      speaker: media_resampling_speaker
      sources:
        - http_media_source
        - sendspin_media_source
    volume_increment: 0.05
    volume_min: 0.4
    volume_max: 0.9
    on_state:
      then:
        - lambda: |-
            using media_player::MediaPlayerState;
            auto state = id(external_media_player).state;
            if (
              state == MediaPlayerState::MEDIA_PLAYER_STATE_PLAYING ||
              state == MediaPlayerState::MEDIA_PLAYER_STATE_ANNOUNCING
              id(led_green).execute();
            } else {
              id(led_red).execute();
script:
  - id: play_sound
    parameters:
      priority: bool
      sound_file: string
    then:
      - if:
          condition:
            lambda: return priority;
          then:
            - media_player.stop:
                announcement: true
      - lambda: |-
          if ((id(external_media_player).state != media_player::MediaPlayerState::MEDIA_PLAYER_STATE_ANNOUNCING) || priority) {
              ->make_call()
              .set_media_url("audio-file://" + sound_file)
              .set_announcement(true)
              .perform();
  - id: led_red
    then:
      - light.turn_on:
          red: 100%
          green: 0%
          blue: 0%
          brightness: 40%
  - id: led_green
    then:
      - light.turn_on:
          red: 0%
          green: 100%
          blue: 0%
          brightness: 40%
switch:
    icon: "mdi:card-text-outline"
    entity_category: config
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
# Added this to restart the ESPHome device remotely
  - platform: restart
globals:
  - id: boot_sound_played
    type: bool
    restore_value: no
    initial_value: "false"
  - id: boot_announce_active
    type: bool
    restore_value: no
light:
  - platform: esp32_rmt_led_strip
    disabled_by_default: false
    pin: GPIO21
    default_transition_length: 0s
    chipset: WS2812
    num_leds: 1
    rgb_order: grb
    effects:
      - pulse:
          transition_length: 250ms
          update_interval: 250ms
          min_brightness: 50%
          max_brightness: 100%
      - pulse:
          transition_length: 100ms
          update_interval: 100ms
          min_brightness: 50%
Well don’t see anything wrong there. Maybe its a physical thing? How are the parts connected?
I have not played with Toslink so really have little experience of that.
Thanks for checking the yaml.
The Toslink is connected exactly as per the diagram on @RealDeco Github GitHub - RealDeco/SendspinZero: Sendspin Audio Receiver for your Stereo/Amplifier · GitHub - GPIO4 to the Toslink is the only connection, apart from power.
I will explore moving the device in case there is WiFi interference but the distance is only about 2m so I think that unlikely.
Thanks again for your help and suggestions!
I didn’t mean which pin it was connected to, I meant is it soldered rather than jumper cables etc, and are the joints all good.
But wifi could be an issues especially if using a zero board as they don’t have great antennas.
Ah, apologies! Yes, fully soldered.
Update:
I couldn’t find anything wrong with my network and the WAP is now within 1 metre and the ESP32 reports a decent signal strength (-45dbm) but I was still getting random issues and the logs were showing random failures.
I became convinced that the cheap ESP32-S3 Zero board I used was faulty but decided to try something I use on ESP32-C3 Zero boards. I reduced the network power using the output_power argument:
wifi:
  ap:
  output_power: 8.5
So far, so good - I’ll run it for a few hours to check but I’m hopeful this will help.
Good thinking, the C3 uses the same antenna as the zero, as far as I know and it seems to fix the c3’s :slight_smile:
I use that power setting on one of my home made voice boxes using an s3 n16r8 as its the only way to get it to connect, no idea why the others built the same are fine.
Well, that seems to have been the issue. About 8 hours solid playing music and no sign of any issues or log messages.
Weird how the problem suddenly manifested with no changes but this certainly seems to have helped.
I know it’s still in the beta phase, but is it already possible to use sendspin on an ESP32-S3-WROOM-1 (N8R2) with ESPHome version 2026.5.0-dev20260503? My ultimate goal is to connect active speakers via S/PDIF to the ESP and play my music library (MP3 and FLAC files) through Music Assistant.
Here ist my yaml which doesnt work, but maybe someone can give me a hint:
esphome:
  friendly_name: streamer1
  # PSRAM wird für flüssiges Audio-Streaming dringend empfohlen (N8R2 Modell)
  platformio_options:
    board_build.arduino.memory_type: qio_opi
    board_build.f_flash: 80000000L
esp32:
  board: esp32-s3-devkitc-1
  variant: esp32s3
  framework:
    type: arduino
# Enable logging
logger:
  level: DEBUG
# Enable Home Assistant API
api:
ota:
  - platform: esphome
    password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
  networks:
  - ssid: !secret wifi_ssid1
    password: !secret wifi_password1
  - ssid: !secret wifi_ssid2
    password: !secret wifi_password2
  ap:
    ssid: "Streamer1 Fallback Hotspot"
    password: "xxxxxxxxxxxx"
captive_portal:
# Aktivierung des PSRAM (N8R2 hat 2MB Quad-PSRAM)
psram:
  mode: octal
# I2S Audio Konfiguration (Anpassung der Pins je nach DAC)
i2s_audio:
  - id: i2s_bus
    i2s_bclk_pin: GPIO5
    i2s_lrclk_pin: GPIO6
# Lautsprecher-Plattform
speaker:
  - platform: i2s_audio
    dac_type: external
    i2s_audio_id: i2s_bus
    i2s_dout_pin: GPIO02
audio:
  codecs:
    flac:
      buffer_memory: internal
    opus:
      state_memory: internal
      pseudostack:
        threadsafe: false
sendspin:
media_source:
    decode_memory: internal
media_player:
    media_pipeline:
      speaker: mysendspin_speaker
      sources:
        - mysendspin_media_source
There are errors shown in the logfile but I do not understand the reason for these error:
[14:25:54.058][C][logger:219]: Logger:
[14:25:54.058][C][logger:219]:   Max Level: DEBUG
[14:25:54.058][C][logger:219]:   Initial Level: DEBUG
[14:25:54.058][C][logger:226]:   Log Baud Rate: 115200
[14:25:54.058][C][logger:226]:   Hardware UART: USB_SERIAL_JTAG
[14:25:54.062][C][logger:235]:   Task Log Buffer Size: 768 bytes
[14:25:54.081][C][psram:016]: PSRAM:
[14:25:54.110][C][psram:019]:   Available: NO
[14:25:54.139][C][i2s_audio.speaker:048]: Speaker:
[14:25:54.139][C][i2s_audio.speaker:048]:   Pin: 2
[14:25:54.139][C][i2s_audio.speaker:048]:   Buffer duration: 500
[14:25:54.162][C][i2s_audio.speaker:054]:   Timeout: 500 ms
[14:25:54.162][C][i2s_audio.speaker.std:036]:   Communication format: std
[14:25:54.162][C][sendspin.hub:062]: Sendspin Hub:
[14:25:54.162][C][sendspin.hub:062]:   Client ID: 98:88:E0:90:33:98
[14:25:54.162][C][sendspin.hub:062]:   Task stack in PSRAM: NO
[14:25:54.175][E][component:224]:   sendspin is marked FAILED: unspecified
[14:25:54.220][C][speaker_source_media_player:053]: Speaker Source Media Player:
[14:25:54.220][C][speaker_source_media_player:053]:   Volume Increment: 0.05
[14:25:54.220][C][speaker_source_media_player:053]:   Volume Min: 0.00
[14:25:54.220][C][speaker_source_media_player:053]:   Volume Max: 1.00
[14:25:54.221][C][sendspin.media_source:031]: Sendspin Media Source: static_delay_adjustable=NO
[14:25:54.221][E][component:224]:   sendspin.media_source is marked FAILED: unspecified
[14:25:54.250][C][captive_portal:134]: Captive Portal:
[14:25:54.280][C][wifi:1526]: WiFi:
Best regars
Jarny
That board should work, well I know it does with a max98357.
Your psram should be quad not octal I believe. Your framework is going to have to be esp idf. You are going to need the external components as well.
I have no idea about S/PDIF stuff with it but I know a man who does.
RealDeco · GitHub.
Have a look at his sendspin zero stuff
Thanks for the feedback. I switched to the esp-idf framework and the errors have disappeared - great tip. I also corrected the psram mode to quad.
So far, the configuration is starting without any errors in the log. I didn’t need the external components after all it seems the Sendspin source code has already been merged into the dev branch. I am using Esphome builder (dev) plugin.
I can see the player in Music Assistant now.
Next, I’ll check if there is a spdif signal on GPIO2, and then I connect my active speakers using the appropriate terminating resistor.
Thanks a lot for the support!
Jarny
here is yaml for the little esp32-s3 zero's that is both Voice Assistant AND sendspin client in one, and yes it can do it :grin::+1:
i use a WeAct board for DAC and MIC, but could be any other dac + mic.
This is really impressive!
I'll have to get one of those WeAct boards or similar to experiment with it.
I finally found the time to connect a 324 ohm resistor to GPIO02 and solder an RCA jack to it. I then wired the whole thing to the coaxial digital input of my Edifier R1380DB active speakers using an RCA cable.
I measured the output level of the digital signal with an oscilloscope, and it's pretty much exactly 0.55V peak. When I pause the music in Home Assistant, the signal at the GPIO drops to a constant 0V. Despite this, no sound is coming out of the speakers. I’ve checked all the settings; the correct input is selected, and the volume settings are correct as well. The optical digital input of the speakers works perfectly (tested it using my TV as the input source) but unfortunately, I don't have any other device with a coaxial digital output to test if the input on the Edifier speakers is functioning properly..
I don't think the coaxial digital input is defective.
Does anyone have an idea what the issue might be?
Thx Jarny
which device did you wire it to?
It is a an ESP32-S3-WROOM-1 (N8R2)
My configuration is mentioned here Sendspin time message timeouts and bad stuttering / no audio - #11 by Jarny
I am using ESPHome Builder from the dev channel: 2026.6.0-dev20260514
I have no idea how you are achieving this or even if it is possible, all I can add is if it is possible your DAC is going to have to be set as different to external, surely.
This is just guessing.
thats like a zero with twice the flash memory (N4R2), you can try to flash the "NO display Digital" version from here, it uses gpio4 btw GitHub - RealDeco/SendspinZero: Sendspin Audio Receiver for your Stereo/Amplifier · GitHub
