This ties a Sengled smart switch to one ‘light’ in a very simple (but also prescriptive) way.
Requirements
- A Sengled Smart Light Switch (E1E-G7F)
- zigbee2mqtt as your zigbee interface.
Installing the Blueprint
Quick Link
Or you can find the latest version on github.
Button Mappings
© below implies that the value is configurable.
- on: Immediately to 50% ©
- double-on: Immediately to 100%
- off: Immediately off.
- double-off: Immediately off. (looking for suggestions for better use of this.)
- up: Immediately +10% ©
- down: Immediately -10% ©
- long-on: Fade on to the same ‘on’ value (default 50%), over 7 seconds ©
- long-off: Fade off over 7 seconds ©
- long-up: Fade up by 30% © over 1 second ©
- long-down: Fade down by 30% © over 1 second ©
Notes
- This only controls the brightness of the light (i.e. color/color-temp are left unchanged)
- The only thing that MUST be configured, are the ‘Light Switch’, and target ‘Lights’, however, much else is configurable.
Blueprint Code
blueprint:
name: Sengled Smart Switch, Prescriptive, by barryred
description: |
This ties one 'light' to one Sengled smart switch.
- This only controls the brighness of the light (i.e. color and color-temp are left unchanged)
- The only thing that MUST be configured, are the 'Light Switch', and target 'Lights', however, much else is configurable.
- © below implies that the value is configurable.
* on: Immediately to 50% ©
* double-on: Immediately to 100%
* off: Immediately off.
* double-off: Immediately off. (looking for suggestions for better use of this.)
* up: Immediately +10% ©
* down: Immediately -10% ©
* long-on: Fade on to the same 'on' value (default 50%), over 7 seconds ©
* long-off: Fade off over 7 seconds ©
* long-up: Fade up by 30% © over 1 second ©
* long-down: Fade down by 30% © over 1 second ©
domain: automation
input:
source_light_switch:
description: 'The Sengled light switch/remote (E1E-G7F) (this is the "..._action" entity)'
selector:
entity:
domain: sensor
target_light:
description: The lights to control with the switch/remote.
selector:
entity:
domain: light
default_on_value:
name: Default On Value
description: The percentage to set the lights to when 'on' is pressed. (Note, long-on will set them to 100, so something other than that is likely better here, unless that's what you always want!)
default: 50
selector:
number:
min: 1
max: 100
unit_of_measurement: '%'
fade_increment:
name: Fade Increment
description: The percentage to fade the lights up/down by per step
default: 10
selector:
number:
min: 1
max: 100
fade_duration:
description: Long on/off fades the lights; This controls the duration of that fade transition.
default: 7
selector:
number:
min: 0
max: 3600
unit_of_measurement: 'seconds'
long_fade_increment:
name: Long Fade Increment
description: The percentage to fade the lights up/down by per step, when up/down is long-pressed.
default: 30
selector:
number:
min: 1
max: 100
long_fade_duration:
name: Long Fade Duration
description: The time to take to fade the lights up/down when up/down is long-pressed.
default: 1
selector:
number:
min: 0
max: 3600
mode: queued
- platform: state
entity_id: !input source_light_switch
attribute: action
to: 'on'
- platform: state
attribute: action
to: 'off'
- platform: state
attribute: action
to: 'up'
- platform: state
attribute: action
to: 'down'
- platform: state
attribute: action
to: 'on_double'
- platform: state
attribute: action
to: 'on_long'
- platform: state
attribute: action
to: 'off_double'
- platform: state
attribute: action
to: 'off_long'
- platform: state
attribute: action
to: 'down_long'
- platform: state
attribute: action
to: 'up_long'
variables:
fade_increment: !input fade_increment
negative_fade_increment: "{{ - fade_increment }}"
long_fade_increment: !input long_fade_increment
negative_long_fade_increment: "{{ - long_fade_increment }}"
- choose:
- conditions:
- condition: trigger
sequence:
- service: light.turn_on
brightness_pct: !input 'default_on_value'
entity_id: !input 'target_light'
- conditions:
sequence:
brightness_pct: 100
- conditions:
sequence:
transition: !input 'fade_duration'
- conditions:
sequence:
- service: light.turn_off
data: {}
- conditions:
sequence:
data: {}
- conditions:
sequence:
- conditions:
sequence:
brightness_step_pct: "{{ fade_increment }}"
- conditions:
sequence:
brightness_step_pct: "{{ long_fade_increment }}"
transition: !input 'long_fade_duration'
- conditions:
sequence:
brightness_step_pct: "{{ negative_fade_increment }}"
- conditions:
sequence:
brightness_step_pct: "{{ negative_long_fade_increment }}"
Related Links
- The latest version is here: GitHub - barryred/home_assistant_blueprints: Blueprints for Home Assistant
- The zigbee2mqtt page for the switch is here: Sengled E1E-G7F control via MQTT | Zigbee2MQTT
