Senor Config Help
I currently have a ESP8266 sending temperature and humidity readings to a MQTT server, I then am trying to use HA to read those values on the MQTT server. But i cant get HA to show any senors or readings.
what i know:
  • HA connects to the MQTT server based on the server logs.
  • MQTT is getting values from the ESP8266 and storing them.
Not sure what im doing wrong. i have 2 different Sensors to see if anything works.
mqtt:
  broker: m13.cloudmqtt.com
  port: 15982
  username: user
  password: user
sensor2:
  platform: mqtt
  state_topic: "sensor/humidity"
sensor3:
  - platform: mqtt
    state_topic: "sensor/temperature"
I think the problem is your yaml
sensor2:
will not be recognized by HA.as sensors
try
  - platform: mqtt
  - platform: mqtt
