borgeolsen
(selvesteolsen)
1
I have two Sensative Strips Comfort. I want to use them to check moisture in a room, and start an automation based on the moisture level.
My problem is that the Sensative SC does not update very ofen. Many hours between the updates. Can I do something to make it report more often?
Tinkerer
(aka DubhAd on GitHub)
2
borgeolsen
(selvesteolsen)
3
Thank you!
I have seen this one earlier, but I am not sure how to do these changes to my system. Could anyone please help me with step-by-step instructions?
Tinkerer
4
Not step by step, but in general:
- Go to the Z-Wave control panel
- Go to Z-Wave Node Management
- Select your node
- Go to Node config options
- Find the config parameter
- Change it
- Hit Set config parameter
- Wake the strip following the instructions that came with it
