Sense API Timeout?
I’ve been using the Sense energy monitor in HA for some time now, and the past few days have been getting API timeout errors. Curious if others are seeing the same. I note that status.sense.com shows no current issues.
  File "/usr/local/lib/python3.9/site-packages/sense_energy/asyncsenseable.py", line 141, in _api_call
    async with self._client_session.get(
  File "/usr/local/lib/python3.9/site-packages/aiohttp/client.py", line 1138, in __aenter__
    self._resp = await self._coro
  File "/usr/local/lib/python3.9/site-packages/aiohttp/client.py", line 559, in _request
    await resp.start(conn)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/client_reqrep.py", line 913, in start
    self._continue = None
  File "/usr/local/lib/python3.9/site-packages/aiohttp/helpers.py", line 721, in __exit__
    raise asyncio.TimeoutError from None
asyncio.exceptions.TimeoutError
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 335, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/sense/__init__.py", line 79, in async_setup_entry
    await gateway.get_monitor_data()
  File "/usr/local/lib/python3.9/site-packages/sense_energy/asyncsenseable.py", line 177, in get_monitor_data
    json = await self._api_call("app/monitors/%s/overview" % self.sense_monitor_id)
  File "/usr/local/lib/python3.9/site-packages/sense_energy/asyncsenseable.py", line 154, in _api_call
    raise SenseAPITimeoutException("API call timed out") from ex
sense_energy.sense_exceptions.SenseAPITimeoutException: API call timed out
