Sense component not working in 0.94
Good afternoon friends,
I just installed a sense home energy monitor. I bought it because I was excited to have some triggers based on things turning on or off. But, it looks like the component is broken. Anyone had any luck?
2019-08-02 01:07:36 INFO (MainThread) [homeassistant.setup] Setting up sense
2019-08-02 01:07:41 INFO (MainThread) [homeassistant.setup] Setup of domain sense took 5.3 seconds.
2019-08-02 01:07:43 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.sense
2019-08-02 01:07:44 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new binary_sensor.sense entity: binary_sensor.steps
2019-08-02 01:07:44 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new binary_sensor.sense entity: binary_sensor.master_bedroom_lights
2019-08-02 01:07:44 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new binary_sensor.sense entity: binary_sensor.ds_hall_6
2019-08-02 01:07:44 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new binary_sensor.sense entity: binary_sensor.ds_hall_door
2019-08-02 01:07:44 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new binary_sensor.sense entity: binary_sensor.master_f_l
2019-08-02 01:07:44 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new binary_sensor.sense entity: binary_sensor.hallway_lights
2019-08-02 01:07:44 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new binary_sensor.sense entity: binary_sensor.bed_c_1
2019-08-02 01:07:44 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new binary_sensor.sense entity: binary_sensor.kitchen_lights
2019-08-02 01:07:44 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new binary_sensor.sense entity: binary_sensor.ds_hall_2
2019-08-02 01:07:44 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new binary_sensor.sense entity: binary_sensor.office_desk
2019-08-02 01:07:44 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new binary_sensor.sense entity: binary_sensor.stairs
2019-08-02 01:07:44 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new binary_sensor.sense entity: binary_sensor.living_room_lights
2019-08-02 01:07:50 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.sense
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/sense/sensor.py", line 121, in async_update
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/sense/sensor.py", line 61, in update_active
  File "/srv/homeassistant/lib/python3.7/site-packages/sense_energy/asyncsenseable.py", line 41, in update_realtime
  File "/srv/homeassistant/lib/python3.7/site-packages/sense_energy/asyncsenseable.py", line 47, in async_realtime_stream
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/sense/__init__.py", line 58, in async_sense_update
I second this
2019-08-09 19:42:26 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.energy_production fails
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 249, in async_update_ha_state
    await self.async_device_update()
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 417, in async_device_update
    await self.async_update()
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/sense/sensor.py", line 120, in async_update
    await self.update_sensor()
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/sense/sensor.py", line 60, in update_active
    await data.update_realtime()
    await self.async_realtime_stream(single=True)
    async with websockets.connect(url) as ws:
  File "/srv/homeassistant/lib/python3.7/site-packages/websockets/client.py", line 519, in __aenter__
    return await self
  File "/srv/homeassistant/lib/python3.7/site-packages/websockets/client.py", line 537, in __await_impl__
    transport, protocol = await self._create_connection()
  File "/usr/lib/python3.7/asyncio/base_events.py", line 986, in create_connection
    ssl_handshake_timeout=ssl_handshake_timeout)
  File "/usr/lib/python3.7/asyncio/base_events.py", line 1014, in _create_connection_transport
    await waiter
  File "/usr/lib/python3.7/asyncio/sslproto.py", line 526, in data_received
    ssldata, appdata = self._sslpipe.feed_ssldata(data)
  File "/usr/lib/python3.7/asyncio/sslproto.py", line 189, in feed_ssldata
    self._sslobj.do_handshake()
  File "/usr/lib/python3.7/ssl.py", line 763, in do_handshake
ssl.SSLError: [SSL: WRONG_SIGNATURE_TYPE] wrong signature type (_ssl.c:1056)
^C
I am on .97
yep, same here:
Error doing job: SSL handshake failed
  File "uvloop/sslproto.pyx", line 500, in uvloop.loop.SSLProtocol._on_handshake_complete
  File "uvloop/sslproto.pyx", line 484, in uvloop.loop.SSLProtocol._do_handshake
  File "/usr/local/lib/python3.7/ssl.py", line 774, in do_handshake
ssl.SSLError: [SSL: WRONG_SIGNATURE_TYPE] wrong signature type (_ssl.c:1076)
anyone made any progress (its shown up 9348 times in 1 day lol) ?
I just disabled it until i hear different.
the edit to the docker seemed to work:
i copied the file out of my docker container, edited it, and copied it back.
Workaround though
