Just got a new Sensi ST75 thermostat and would like to add this to Home Assistant locally using the HomeKit controller, as I’ve seen some posts around saying that is possible.
If it helps, I’m running firmware version 6004971003 (build date 05/18/2022). The thermostat was added using the Sensi app (not HomeKit) to an isolated network with no internet connection, so it says “connected to Wi-Fi, not connected to the cloud”.
From the server (HA core), avahi-browse
seems to be able to locate the thermostat, but python3 -m netdisco
is returning nothing:
root@hass:~# avahi-browse -a
+ ens224 IPv4 Sensi-YYYYYY _hap._tcp local
root@hass:~# python3 -m netdisco
Discovered devices:
Discovered 0 devices
root@hass:~# tcpdump -ni ens224 port 5353 -X
23:54:37.345870 IP 192.168.2.37.5353 > 224.0.0.251.5353: 0*- [0q] 6/0/0 (Cache flush) A 192.168.2.37, (Cache flush) AAAA fe80::366f:XXXX:XXXX:XXXX, PTR YYYYYY.local., (Cache flush) SRV YYYYYY.local.:80 0 0, PTR Sensi-YYYYYY._hap._tcp.local., (Cache flush) TXT "c#=1" "ff=1" "id=D5:CE:4A:XX:XX:XX" "md=ST75" "pv=1.1" "sf=1" "ci=9" "s#=1" "sh=XXXXXX==" (360)
root@hass:~# ping 192.168.2.37
PING 192.168.2.37 (192.168.2.37) 56(84) bytes of data.
64 bytes from 192.168.2.37: icmp_seq=1 ttl=255 time=89.3 ms
64 bytes from 192.168.2.37: icmp_seq=2 ttl=255 time=6.47 ms
root@hass:~# avahi-resolve -a 192.168.2.37
192.168.2.37 YYYYYY.local
root@hass:~# avahi-resolve -n YYYYYY.local
YYYYYY.local 192.168.2.37
The HomeKit controller integration keeps saying “no unpaired devices could be found”.
Any ideas on why the integration isn’t able to find/connect to the device, and tips on how to make this work?
(edit) Maybe this is part of the problem:
root@hass:~# avahi-browse -ar
Failed to resolve service 'Sensi-YYYYYY' of type '_hap._tcp' in domain 'local': Timeout reached
(edit #2) Looks like that happens when the thermostat is not in the “Wi-Fi setup” screen. With that, we now have:
= ens224 IPv4 Sensi-YYYYYY _hap._tcp local
hostname = [YYYYYY.local]
address = [192.168.2.37]
port = [80]
txt = ["sh=XXXXXX==" "s#=1" "ci=9" "sf=1" "pv=1.1" "md=ST75" "id=D5:CE:4A:XX:XX:XX" "ff=1" "c#=1"]
Still nothing in python3 -m netdisco
or the HomeKit controller integration though.
