For 2 - 3 (Sep. 2017) Weeks now Sensibo component won’t load any more.
It throws the following error when it starts
2017-10-13 18:00:38 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform sensibo
File “/usr/src/app/homeassistant/helpers/entity_component.py”, line 164, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/local/lib/python3.6/asyncio/futures.py”, line 245, in result
raise self._exception
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 180, in _step
result = coro.send(None)
File “/usr/src/app/homeassistant/components/climate/sensibo.py”, line 55, in async_setup_platform
devices.append(SensiboClimate(client, dev))
File “/usr/src/app/homeassistant/components/climate/sensibo.py”, line 76, in init
self._do_update(data)
File “/usr/src/app/homeassistant/components/climate/sensibo.py”, line 87, in _do_update
temperature_unit_key = self._ac_states[‘temperatureUnit’]
KeyError: ‘temperatureUnit’
I bought my Sensibo for a couple of weeks ago and it worked just fine for a few days. Now HA can’t change the temperature anymore. Error log doesn’t show anything, but haven’t tried to debug yet.
If I change the temperature with the Sensibo app, HA updates with the correct temperature, so the API works somehow. Still the same issue from 0.56 to 0.57.
Hi, I’m trying to install two sensibo in HA but as soon as I add the code in configuration.yaml all my other climate component just disapear and nothing showup for sensibo.
