Hi
I’m about to switch my home automation from IP Symcon to HA. Now I have the following issue:
Whenever HA sends a command to the API, the AC confirms the command with a beep. That’s usually a wanted reaction, however not for every situation. Example: I’ve programmed to enable Clima React tusn on at 10pm and turn off at 4am. The 10pm isn’t really an issue but the loud beep at 4am wakes me up.
In IP Symcon and by using the Sensibo web interface, there are no beeps acknowliging the command. In the Sensobo web UI it depends which remote control is simulated.
Is there a way to configure the remote control in the HA integration or add a config parameter to disable the loud beeps for commands?
Many thanks
Daniel
