I have a annoying issue with heater controlled by Sensibo. Automation is triggered when Nordpool energy price is changed (every hour). I control the temperature according to cheapest hours in Nordpool. Automation works ok but it is annoying. When automation is triggered it sends the target temperature to heater and it does it even the last target has been same. Heater peeps every time when new target is send (every hour). It should send the target temperature only if the target differs from previous one.
How to compare is the new target same as the previous one ?
This is what I want:
if
previous target temperature is same as the new one
then
do nothing (don’t send the target to heater via Sensibo)
else
send a new target to heater
This is the automation yaml-code:
alias: Ilpin ohjaus
description: ""
- platform: state
entity_id:
- input_number.ilpin_hintaraja_kuumaksi
- input_number.ilpin_kuuma_lampotila
- input_boolean.ilpin_automaatio_paalla
- input_number.peruslampo
- sensor.nordpool
- platform: homeassistant
event: start
- platform: numeric_state
entity_id:
- sensor.shellyuni_08f9e0518490_temperature
for:
hours: 0
minutes: 30
seconds: 0
below: 10
entity_id:
- sensor.shellyplusht_a0a3b3de69e4_temperature
for:
hours: 0
minutes: 30
seconds: 0
below: 22
condition: []
- if:
- condition: and
conditions:
- condition: numeric_state
entity_id: sensor.nordpool
below: sensor.kytkentaraja124
entity_id: sensor.shellyuni_08f9e0518490_temperature
below: 10
- condition: state
entity_id: input_boolean.ilpin_automaatio_paalla
state: "on"
entity_id: sensor.shellyplusht_a0a3b3de69e4_temperature
below: 21
then:
- service: climate.set_temperature
metadata: {}
temperature: "{{ states('input_number.ilpin_kuuma_lampotila')| float(0) }}"
entity_id: climate.matti_s_device
else:
metadata: {}
temperature: "{{ states('input_number.peruslampo')| float(0) }}"
mode: single
Many thanks in advance!
