Sensibo Sky Exposed Sensors
I have a question about the Sensibo integration.
With the Sky model, what all sensors are available to Home Assistant? I’m looking for temp and humidity to be available.
I’ve read the integration docs but reading those I seem to understand the temp and humidity (along with motion) are only available using the Air model along with the room sensors.
However, reading the forum, maybe that’s not the case. I see some references to those sensors even using just the Sky model.
Which one is correct?
Hello… have you figure out if the Sensibo Sky work well in HA?
i am looking to buy one… just need to control… on/off and temperature
Andre
Yes, they work great! No issues to report at all. I added two of them not long after the original post and haven’t had any problems. Was even able to add some “features” that weren’t on my original remotes for the ACs
Hi
any way to control the swing?
What feature did you find?
Andre
Didn’t look at swinging but I was able to make a script to turn on strong mode on the fan indefinitely. From my remote it only runs that for 20 minutes. Plus was able to get the humidity sensors as separate entities
Hi Could you share you script?
