Hi there,
I am hoping that I am misunderstanding something due to being new to HA, but I seem to have a problem with the Sensibo Sky integration and how it is controlled within in HomeKit.
The three main issues are…
- There doesn’t seem to be an option to select DRY mode.
- There are only 3 fan speeds controlled by a vertical switch. There should be 5 which can be controlled by a horizontal selector when you swipe down on the device.
- There doesn’t seem to be any way to set the fan speed when creating an automation. Just simply to turn the aircon on or off and set the temp.
I used HOOBs in the past to expose Sensibo to Homekit and all three of those issues weren’t present when using that. Is this just a limitation of the way HA exposes Sensibo to Homekit, or are their settings that I should (but seemingly cannot find to) change?
Many thanks.
