Great work, my Sensibo arrived today and thanks to your efforts is already integrated with HA.
I’m having an intermittent issue with connection to the sensibo api, :
17-01-10 23:38:01 homeassistant.core: Error doing job: Task exception was never retrieved
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 138, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/util/connection.py", line 98, in create_connection
raise err
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/util/connection.py", line 88, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 594, in urlopen
chunked=chunked)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 350, in _make_request
self._validate_conn(conn)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 835, in _validate_conn
conn.connect()
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 281, in connect
conn = self._new_conn()
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 147, in _new_conn
self, "Failed to establish a new connection: %s" % e)
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x69ec10b0>: Failed to establish a new connection: [Errno 111] Connection refused
File "/srv/homeassistant/lib/python3.4/site-packages/requests/adapters.py", line 423, in send
timeout=timeout
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 643, in urlopen
_stacktrace=sys.exc_info()[2])
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/util/retry.py", line 363, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
requests.packages.urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='home.sensibo.com', port=443): Max retries exceeded with url: /api/v2/users/me/pods?fields=id%2Croom&apiKey=myapikeyhere (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x69ec10b0>: Failed to establish a new connection: [Errno 111] Connection refused',))
File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
result = coro.throw(exc)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 386, in _update_entity_states
yield from update_coro
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 216, in async_update_ha_state
yield from self.hass.loop.run_in_executor(None, self.update)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/home/homeassistant/.homeassistant/custom_components/climate/sensibosettingsonly.py", line 137, in update
devices = client.devices()
File "/home/homeassistant/.homeassistant/custom_components/climate/sensibosettingsonly.py", line 37, in devices
result = self._get("/users/me/pods", fields="id,room")
File "/home/homeassistant/.homeassistant/custom_components/climate/sensibosettingsonly.py", line 26, in _get
response = requests.get(_SERVER + path, params = params)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/api.py", line 70, in get
return request('get', url, params=params, **kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/api.py", line 56, in request
return session.request(method=method, url=url, **kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/sessions.py", line 488, in request
resp = self.send(prep, **send_kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/sessions.py", line 609, in send
r = adapter.send(request, **kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/adapters.py", line 487, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='home.sensibo.com', port=443): Max retries exceeded with url: /api/v2/users/me/pods?fields=id%2Croom&apiKey=myapikeyhere (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x69ec10b0>: Failed to establish a new connection: [Errno 111] Connection refused',))
17-01-10 23:38:02 homeassistant.components.media_player.onkyo: Resetting connection to AVReceiver.
17-01-10 23:38:02 custom_components.switch.sensiboswitch: Sensibo uid =ZV4XJxEU
17-01-10 23:38:02 homeassistant.core: Error doing job: Task exception was never retrieved
raise err
sock.connect(sa)
chunked=chunked)
conn.connect()
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x6e0ee8d0>: Failed to establish a new connection: [Errno 111] Connection refused
timeout=timeout
requests.packages.urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='home.sensibo.com', port=443): Max retries exceeded with url: /api/v2/pods/ZV4XJxEU/acStates?fields=status%2Creason%2CacState&apiKey=myapikeyhere&limit=1 (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x6e0ee8d0>: Failed to establish a new connection: [Errno 111] Connection refused',))
File "/home/homeassistant/.homeassistant/custom_components/switch/sensiboswitch.py", line 103, in update
current_settings = client.pod_ac_state(uid)
File "/home/homeassistant/.homeassistant/custom_components/switch/sensiboswitch.py", line 44, in pod_ac_state
result = self._get("/pods/%s/acStates" % podUid, limit = 1, fields="status,reason,acState")
File "/home/homeassistant/.homeassistant/custom_components/switch/sensiboswitch.py", line 25, in _get
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='home.sensibo.com', port=443): Max retries exceeded with url: /api/v2/pods/ZV4XJxEU/acStates?fields=status%2Creason%2CacState&apiKey=myapikeyhere&limit=1 (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x6e0ee8d0>: Failed to establish a new connection: [Errno 111] Connection refused',))
Any help appreciated.
