I want to display the date and time of an entity on my dashboard but since the last HA update this isn’t possible anymore. The state of my entity is unknown. I have several warnings in my log:
Yes, I know about the changes around the device_class but I can’t figure out what I have to change to simply display the input sensor in this format: 21-12-2021 09:47:34
You have defined a timestamp sensor, which requires a date and time value in ISO8601 format, but you have not supplied it with a value in the required format. That’s why the message states:
How you want the time to appear is different from what a timestamp sensor requires. If you remove device_class: timestamp then you can use whatever date and time format you want. However, the resulting cannot be used in a Time Trigger.
Hi all, I have 3 sensors set up, 2 of them are fine, however 1 isn’t. I’ve removed device_class from all 3 but when I look at the Developer tools / States, the device_class is still there.
I have done several reboots and checked my customize.yaml and there is no mention of it.
