I have a template sensor, that I use to calculated the weighted average from some thermometers:
template:
- name: atc_temperature
unit_of_measurement: "°C"
state: >
{% set n=0 %}
{% set t=0 %}
{% if is_state('input_boolean.atc1', 'on') and not is_state('sensor.atc1_temperature', 'unavailable') %} {% set n=n+1 %} {% set t=t+(states('sensor.atc1_temperature') | float ) %} {% endif %}
{% if is_state('input_boolean.atc2', 'on') and not is_state('sensor.atc2_temperature', 'unavailable') %} {% set n=n+1 %} {% set t=t+(states('sensor.atc2_temperature') | float ) %} {% endif %}
{% if is_state('input_boolean.atc3', 'on') and not is_state('sensor.atc3_temperature', 'unavailable') %} {% set n=n+1 %} {% set t=t+(states('sensor.atc3_temperature') | float ) %} {% endif %}
{% if is_state('input_boolean.atc4', 'on') and not is_state('sensor.atc4_temperature', 'unavailable') %} {% set n=n+1 %} {% set t=t+(states('sensor.atc4_temperature') | float ) %} {% endif %}
{% if is_state('input_boolean.atc5', 'on') and not is_state('sensor.atc5_temperature', 'unavailable') %} {% set n=n+1 %} {% set t=t+(states('sensor.atc5_temperature') | float ) %} {% endif %}
{% if is_state('input_boolean.atc6', 'on') and not is_state('sensor.atc6_temperature', 'unavailable') %} {% set n=n+1 %} {% set t=t+(states('sensor.atc6_temperature') | float ) %} {% endif %}
{% if is_state('input_boolean.atc7', 'on') and not is_state('sensor.atc7_temperature', 'unavailable') %} {% set n=n+1 %} {% set t=t+(states('sensor.atc7_temperature') | float ) %} {% endif %}
{% if is_state('input_boolean.atc8', 'on') and not is_state('sensor.atc8_temperature', 'unavailable') %} {% set n=n+1 %} {% set t=t+(states('sensor.atc8_temperature') | float ) %} {% endif %}
{% if (n > 0) %} {{ (t / n) | float }} {% endif %}
Now, I have a sensor card, that I use to display this sensor:
type: sensor
entity: sensor.atc_temperature
icon: mdi:thermometer
unit: ºC
detail: 2
graph: line
What I see on this card is this:
(notice how the temperature seems to be very stable)
However, when clicking on that card, this other image pops-up:
(notice the amount of detail, and the variation in temperature)
What am I doing wrong? Why is the card not showing any detail at all?
