Hi, I have configured ESPHome on ESP32 device. I have connected 3 sensors to it. SGP4x, LD2420 and DHT22. I have compiled and uploaded the firmware successfully. Everything works fine when all but DHT22 sensor is connected. After I connect DHT22, the device throws an API error and is unable to connect to Home Assistant
INFO ESPHome 2024.2.2
INFO Reading configuration /config/esphome/esphome-web-05ada8.yaml...
INFO Starting log output from 192.168.3.236 using esphome API
WARNING Can't connect to ESPHome API for esphome-web-05ada8 @ 192.168.3.236: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.3.236', port=6053))]: [Errno 113] Connect call failed ('192.168.3.236', 6053) (SocketAPIError)
INFO Trying to connect to esphome-web-05ada8 @ 192.168.3.236 in the background
