I have some binary window sensors. I gave them sensor_class “opening” and the are shown as opening in the dev tools. But it shows on/off only.
What can i do?
What can i do?
I don’t understand. Doors have the same sensor_class… its opening. The same with windows. Or what do you mean?
All binary sensors report their state as on/off currently. That is the feature request to be able to customize the text. It’s not possible currently. Your only option is use a template sensor, but then you lose the icon that the binary sensor uses.
Sensor class is mainly used to determine what default icon to show. (Just found this out last week.)
Why is the manual saying something else?
Manual Binary_Sensor: Most binary sensors support the sensor_class: which let you specify the type of your sensor.
Is this feature still on todo?
No, that feature works. You’ll notice that by changing the sensor_class, the icon will change. It just doesn’t change the text. That’s essentially what the feature request I linked to is asking for.
