Sensor.Community - failed to connect
Hi everyone,
I have a particle sensor and share the data with the sensor.community.
But if I try to activate the integration sensor.community with any sensor, it fails to connect:
There is obviously not a lot I could do wrong, so I wonder if there’s a bug!?
No one with this issue?
Hi I do have the same issue.
Even if that is not the same, I have tried opensensemap and this one is working.
I was able to have the sensor.community plugin working back in the days.
Thank you Sam for the response.
So, what you are saying, that sensor.community is also not working on your side (but it was in the past).
And you tried opensensemap as an additional check!?
I just recognized that I tried to install it locally (LAN URL), so I tried it with the cloud URL as well (nabu casa).
However, I don’t even get an error message in this case.
